jimny trim
- suzuki jimny fella
21 Dec 2011 17:51 #28845
by suzuki jimny fella
jimny trim was created by suzuki jimny fella
what is the best way to remove the archs and cut out what i dont what there and whats the best way to put them back on
i be told that the clips do brake and you got to glue them back on
can you help
thanks
can you help
thanks
- reaper
21 Dec 2011 18:01 #28849
by reaper
Replied by reaper on topic Re: jimny trim
there used to be a tool for the clips , would be easy to make
some flat bar 2-3mm thick with a slot cut in the end , push this between the body and trim so the slot goes around the clip
then give it a gentle tug as you are exerting the same force all around the clip its less likely to snap
- SOTA
21 Dec 2011 18:48 #28858
by SOTA
Replied by SOTA on topic Re: jimny trim
That must be the problem on mine, the trim won't go back on, but it's dark outside and I can't see a thing.
- myers647
21 Dec 2011 19:11 #28861
by myers647
Replied by myers647 on topic Re: jimny trim
Hi there uv taken mine off a couple of times and replaces them without using any glue. If you want there is a tool on eBay (panel removing tool) I think it's named as, but this could be very easily made as already said. To put back on I always put the clips back on the body then offer the trim back up to the clips and give it a tap and it should clip back on one by one. If not you can get the new clips off eBay for pence or your local Suzuki garage. You might find some rust under neith these trims especially on the arches. Very easy to trim with a jig saw.
Thanks
James
Thanks
James
21 Dec 2011 19:58 #28866
Replied by suzuki jimny fella on topic Re: jimny trim
thanks
- dirtydogz
21 Dec 2011 20:34 #28873
by dirtydogz
Replied by dirtydogz on topic Re: jimny trim
www.amazon.co.uk/s/?ie=UTF8&keywords=car...ef=pd_sl_6j4dmt2s2_b
Hope this helps you
Hope this helps you
Time to create page: 0.106 seconds
