fuel saving /power booster
- anth69y
16 Aug 2011 20:14 #20508
by anth69y
fuel saving /power booster was created by anth69y
hi everyone
just wondered if any of you good people have fitted a fuel /power boost chip like this
www.tuningwizard.co.uk/index.php?main_pa...119&products_id=2254
if so what do you think ,do they improve power or fuel consumption like they state or do they bugger up your jimny ?
- mark1971
17 Aug 2011 03:57 #20518
by mark1971
Replied by mark1971 on topic Re: fuel saving /power booster
My mate built his own, it's just a potentiometer that makes the ecu think the inlet temp is colder than it actually is and let's more fuel into the mix. 40 bhp is quite an exaggeration in my opinion. Not sure of the long term effects it could have on the engine, I always file these away in the drawer marked urban myth along with those fuel saving magnets that attach to the fuel lines.
- Az1987
17 Aug 2011 04:42 #20520
by Az1987
Replied by Az1987 on topic Re: fuel saving /power booster
As said above they work by tricking your engine ECU in to thinking the air going in to the engine is cooler than it is, so the ECU then up's the fuel. So all they do is make you car run rich all the time which will make you use more fuel and could poss damage the CAT as more fuel in the system means more undurnt fuel in the exhaust and higher emissions come MOT time.
- ooky_123
17 Aug 2011 06:51 #20527
by ooky_123
Replied by ooky_123 on topic Re: fuel saving /power booster
you need some snake oil too ....
17 Aug 2011 10:37 #20539
by facade
Replied by facade on topic Re: fuel saving /power booster
I had the opposite idea on the rangerover (with flapper air meter: I forget the code number)
I put a resistor in parallel with the engine temp sensor to fool it into thinking the engine was warmer to back the choke off and save fuel, as well as stopping it hunting at idle.
A jimny has an exhaust gas sensor that will trim the fuel when running at a steady speed and negate any fiddling with air temperature sensor.
- anth69y
17 Aug 2011 15:18 #20554
by anth69y
Replied by anth69y on topic Re: fuel saving /power booster
that was more the idea not to get more power but to get better mpg ,its a great little plodder which i am happy just pottering around in but if i can improve fuel consumption that would be a bonus .
i wondered if any jimny owner had improved there mpg in any way or if it was as good as it gets from the factory
Time to create page: 0.110 seconds
