Obarno wrote: I think we have been here before on this subject, if yours is a manual VVT it will have a transfer box ratio of 1:1 in high and 2.002:1 in low. The auto VVT uses a different transfer box that is 1.32:1 in high and 2.643:1 in low, so could be an easy swap and still giving you a good reduction.
The manual car has 4.3:1 diffs and I think they are the same for the auto.
If you go the rocklobster route, as I have done, you end up with low gearing both in high and low. Ok unless you want to make long journeys and then it becomes tiresome as at 4000 rpm it's only doing about 100kms per hour even with 30 inch tyres and I have changed my diffs to 3.9:1
That's sounds more like it. Do you happen to know as a percentage what sort of reduction it offers?
Using the auto transfer box will give you a reduction in high of 20% and 32% in low.
Your 235 tyres compared to the original 205 will give you an increase in gearing of 9.88% so you will still be lower with the auto transfer box, but probably not too low.
Essential Always on
Necessary for the operation of the website. These cookies cannot be disabled.
Functional
Enable convenient features and the storing of preferences.
Statistics
Help us understand how visitors use the website (audience measurement).
Marketing
Used for advertising and tracking visitors across websites.
