Removing mud
25 Feb 2011 07:07 #12148
by kirkynut
Replied by kirkynut on topic Re: Removing mud
I gave up using the car wash's / garage's pressure washer as it was costing me a fortune!
They are sometimes higher pressure than a home one, depending how much money you spent on a home one, but that is not necessarily a good thing. The higher pressure ones sometimes remove more than mud - such as your underseal, which stops your car from turning into a big ball of rust very quickly.
I bought a £30 one from B+Q on a last of line offer for a not brilliant brand. I am quite anal about getting every little bit of mud off my Jimny as it retains moisture to cause rust.
To that end I get down on my hands and knees and sometimes lay on my side - in the muddy water on the ground - and clean every nook and cranny. Sometimes with the lower pressure you have to soak it first to loosen it up, then come back to it to blast it out. So I go round once quickly to soak it, then again thoroughly to get it out.
I then find the next day when I'm less tired of looking at the underside of a car with mud flicking in my eyes that I have missed loads and give it a second go quickly to get the bits I missed.
I also try not to put it straight away in the garage and to leave it out to dry in the air, or it will stay wet and surface rust will quickly form.
This summer I intend to complete a good rustproofing session with a liberal application of stone chip to all of the underside. I don't use Waxoyl type products outside the chassis as from bitter experience it never really sets and you get covered in it forever more when working under the car, which I do alot with it being an offroader and the maintenance it needs from that.
I hope that the stonechip will protect the chassis and under the body from rust and prevent the mud from sticking so vigorously to it.
I also plan to blast the chassis out and Wayoyl inside it. This needs doing in 30 degrees heat though to ensure it dries over a week or so first before I stick the Waxoyl inside.
It's a funny old game this Offroading. It's fun doing it, but if you want to keep your truck in good nick like I do, you spend more time cleaning it and maintaining it than you do using it offroad!
- mcjimny
25 Feb 2011 09:37 #12161
by mcjimny
Replied by mcjimny on topic Re: Removing mud
I usually find it takes a couple of goes at it to get it all off too!
I'll echo others on not buying a dear pressure washer, i had a cheap one a while ago and it was fine for the jobs i needed it for until i dropped the lance cleaning out the guttering, obviously a replacement lance is more than the washer itself so that ended up binned as i got a karcher off my sister, which i must say is no better its slightly more powerful but thats it, now the lance is shot on that too, it may just be an o-ring but i've not had chance to take it apart yet. Replacements are £45+
Some people rip it if you have a clean 4x4 but when you work on it yourself theres nothing worse than mud falling in your eyes when you're under your car. I also believe that if its covered in crap you can't see any damage properly.
- darthloachie
25 Feb 2011 18:46 - 25 Feb 2011 18:46 #12172
by darthloachie
Replied by darthloachie on topic Re: Removing mud
so what do you do to clean the engine bay etc ?
Last edit: 25 Feb 2011 18:46 by darthloachie.
- mcjimny
25 Feb 2011 19:02 #12173
by mcjimny
Personally i leave it running and put it on a fine spray and avoid direct spray on electricals. I leave it running for a while after.
darthloachie wrote: so what do you do to clean the engine bay etc ?
Time to create page: 0.285 seconds
