Removing mud
- Smoggy
22 Feb 2011 17:58 #12018
by Smoggy
Removing mud was created by Smoggy
Can anyone out there give best advice on removing thick caked on mud from underside of car. I was thinking of lifting one side onto axle stands then jetwashing and repeating for other side.
- mcjimny
22 Feb 2011 18:07 #12019
by mcjimny
Replied by mcjimny on topic Re: Removing mud
I usually put the front up on ramps, then cross axle it both directions to get under the arches and at the chassis, then one side up so i can get at the centre. Only way you can get a good go at it is by getting on your knees still. Worst part is the radius arm mounts i have to go both directions to clear them out.
- biggaz
22 Feb 2011 21:03 #12026
by biggaz
Replied by biggaz on topic Re: Removing mud
The mud at tong was thin/watery type so not bad at all to clean.... wait till you get real THICK mud. my jetwash wudnt budge it last time mine was like that, had to pull it off with hands.
- Smoggy
22 Feb 2011 21:11 #12028
by Smoggy
Replied by Smoggy on topic Re: Removing mud
maybe take it to local garage jetwash and drive onto ramps without them seeing! they are more powerful than the domestic types i believe
- mcjimny
22 Feb 2011 21:26 #12030
by mcjimny
I've not noticed they're any more powerful but the time it takes to do it properly it will cost a fortune!
Now i know all mud is bad for your car but when i first took mine off road to Manby the mud got everywhere and hammers your components, i think 40-50k of road miles then a good dunking off road finished things off. The sites i use now don't seem so hard on parts even the drums aren't full of mud like they used to be.
- Johnniehec
- Thank you received: 56
24 Feb 2011 13:13 #12096
by Johnniehec
Replied by Johnniehec on topic Re: Removing mud
Ditto what Mcjimny said a pair of ramps, a lot less effort than jack and axle stands. My power washer is just a £30 Homebase jobbie, I always have the opinion that unless your going to spend a grand upwards on a steam cleaner your just as well spending £30 (oops sorry Aberdonian speak again!!)
John.
John.
Time to create page: 0.158 seconds
