ProComp spring length, RHD vs LHD?
- Strek
02 Feb 2011 08:31 - 02 Feb 2011 08:33 #10795
by Strek
ProComp spring length, RHD vs LHD? was created by Strek
Hi all!
I have purchased a 2" procomp lift kit, and wonder which springs go where. I saw a picture of this somewhere, but cant find it.
My car is a left hand drive Jimny (LHD).
I mailed with Russell at Jimnybits, and he told me this:
Hi
It will fit a LHD jimny, one of the front springs will be longer and this spring is for the drivers side, to help with the jimny lean
Yours
Russell Palmer
ÂÂÂ
However, I've also been told on other forums, that LHD jimnys have the same length on the front springs, that RHD only suffer from the lean, and therefore need a longer spring on the driversides rear, not front.
Can someone please explain theese lengths?
Four springs, two the same lenght, one a bit longer, and one the longest:
))))))))))))) nr 1
))))))))))))) nr 2
))))))))))))))) nr 3
))))))))))))))))) nr 4
Which goes where?
Thanks for any reply!
Hi
Yours
Russell Palmer
ÂÂÂ
))))))))))))) nr 1
))))))))))))) nr 2
Which goes where?
Last edit: 02 Feb 2011 08:33 by Strek.
- srcars
02 Feb 2011 08:45 #10796
by srcars
Replied by srcars on topic Re: ProComp spring length, RHD vs LHD?
The longer spring is to offset the fact that the car will always have weight in the drivers seat and will sag before the rest.
Therefore I would say.
longest spring = drivers side front (front left for you)
second longest = passenger front
other two = rear
other two = rear
02 Feb 2011 08:50 #10797
Replied by mlines on topic Re: ProComp spring length, RHD vs LHD?
The Suzuki original springs are "handed" on RHD cars and "not handed" on LHD cars, people from Europe do not report the Jimny Lean issue. So it sounds like a RHD issue.
Therefore you probably need to investigate further why the Pro-Comp kit has handed springs when you have a LHD car. Certainly the Trailmaster kits, which originated in Europe, are not handed and speaking to their technical department they have neve come across the "Jimny Lean" issue.
- Strek
02 Feb 2011 10:05 #10808
by Strek
Replied by Strek on topic Re: ProComp spring length, RHD vs LHD?
Hmm..
Handed, what does that mean?
So, the LHD set consist of to set of equal length springs? Two short and two long?
)))))))))) Rear
)))))))))))) Front
And that would mean that fitting my procomp set on my LHD Jimny, would cause a "negative" lean, that meaning a bigger lift on the driver side?
If so, the solving would be to cut the longest spring to match with the second longest in the set?
Am I right?
)))))))))) Rear
)))))))))))) Front
Am I right?
- adamjimny
02 Feb 2011 10:17 #10811
by adamjimny
Replied by adamjimny on topic Re: ProComp spring length, RHD vs LHD?
or just make up the difference with a spacer i wouldn't cut the springs as iv been told it stiffens the spring but unsure and to be honest i would never cut it.
just get a spacer to make it match the other side saves the hassel
02 Feb 2011 10:31 #10813
I would probably end up fitting the longer springs to the Drivers side because, if for no other technical reason, most Jimny drivers like eating Doughnuts.
In a RHD Jimny, the Driver, the Battery and the Panhard rod "pull" all works in the same direction, probably creating the lean.
In a LHD Jimny the Driver counterbalances the Battery and the Panhard rod "pull" so it perhaps cancels out.
If you fit the longer springs to the Driver side it may sit a bit higher but this will disappear once you sit in it.
Time to create page: 0.168 seconds
