ProComp spring length, RHD vs LHD?
05 Feb 2011 07:07 - 05 Feb 2011 08:55 #10983 by mlines
You are correct. In RHD Jimnys the handed springs are at the rear. Hard to tell from the parts manual what the difference is but its at the rear.
Last edit: 05 Feb 2011 08:55 by mlines.
  • srcars
05 Feb 2011 07:47 #10985 by srcars
Replied by srcars on topic Re: ProComp spring length, RHD vs LHD?
If the Jimny had any I would suggest the longer spring may be to counter the twisting from the engine torque :whistle:
  • Ranster
05 Feb 2011 10:16 - 05 Feb 2011 10:24 #10989 by Ranster
Replied by Ranster on topic Re: ProComp spring length, RHD vs LHD?
I found the installation manual and the long spring goes to the Rear - right hand.
I also found this interesting PDF from Old Man Emu (OME) which offer same specs as the king springs
www.rocky-road.com/jimny.pdf
** take a look on the remarks regarding the Jimny REAR springs:
OME966 suits japanese built models (RHD) with a 20mm higher right hand side coil.
OME967 suits european built models (LHD) with equal height coils.
Last edit: 05 Feb 2011 10:24 by Ranster.
  • Ranster
05 Feb 2011 11:47 #10994 by Ranster
Another input - those are the part numbers taken from suzuki EPC.
As you can see, both front and both rear springs are identical in a LHD Jimny.
For a RHD Jimny there are different part numbers for the left and right springs in the back.
LHD Jimny:
41111-84A00 - SPRING, FRONT COIL
41311-81A40 - SPRING, REAR COIL RH
41311-81A40 - SPRING, REAR COIL LH
RHD Jimny:
41311-81A50- SPRING, LEFT COIL LH
41311-81A30- SPRING, LEFT COIL LH
btw, my car is a 2006 Jimny SN415VD-4 series.
  • Strek
05 Feb 2011 17:18 #11023 by Strek
Replied by Strek on topic Re: ProComp spring length, RHD vs LHD?
Once again, what does "handed" mean?
05 Feb 2011 17:31 #11025 by mlines
I use the term "handed" to mean they only fit one way. So, for example, track rod ends are "handed". They come in left hand versions and right hand versions and the left only fit the left side and the right only fit the right side.
Gloves are often "handed". The left hand gloves only fit the left hand (due to the thumb position") etc.
Therefore "handed" springs are design to fit on one side of the car, but not the other side.
