Another green laner build
09 Sep 2021 19:57 - 09 Sep 2021 19:59 #238409
by LesNewell
Another green laner build was created by LesNewell
I recently purchased a 2001 Jimny auto as a more comfortable green laning alternative to my trials car. The trials car is remarkably effective off road even though it is 2WD and runs road tyres but the lack of doors makes it pretty uncomfortable in the winter.When I first looked at the Jimny I spotted some rust and dubious patches but the price seemed right. After getting it on the lift and attacking it with the rust finder 9000 (needle gun) things started going downhill fast. First the rear wheel arches. Left hand rust cut out ready for patching
With patch. I really need more practice welding bodywork. It's been a while since I worked on steel this thin. 0.6mm wire would probably help but the smallest I have here is 0.8.
The right hand side had been patched but I couldn't stand seeing the family of dead caterpillars masquerading as welds. It had to go. Here it's nearly ready for teh patch.
The welds may not be pretty but at least they are solid.
Right hand rear outrigger next. It didn't look too bad until I attacked it with the needle gun and cut out the reinforcing gusset (aka mud trap)..
After staring at it a bit I decided the best route was to cut it all off and start again. Most of the cup could be saved but the rest was toast. After adding some steel:
And glued back on the chassis
Last edit: 09 Sep 2021 19:59 by LesNewell.
09 Sep 2021 20:18 - 09 Sep 2021 20:36 #238410
by LesNewell
Replied by LesNewell on topic Another green laner build
On to the middle outriggers. Both had badly rotted gussets. The chassis behind the gussets was pretty thin so I pad welded it to build up the thickness. Looking closely at the way the gussets were originally attached I'm not convinced they added a significant amount of strength. I don't think it's worth replacing them. What do you think?
Let's have a poke at the left rear outrigger. The gusset was toast but otherwise the outrigger was not too bad. After building up a few thin areas and adding a new gusset:
Hmm, the inside of the rear crossmember looks a bit scabby but the outside looks solid. Let's see what happens if I poke the needle gun down there. Umm, that's not good. The rust finder 9000 strikes again.
Let's try the other side. Yikes! That's really not good. I think if this was left I'd have had a rear shock poking through the floor and saying hi within a few months.
The panhard mount brace is looking a bit holey too.
Last edit: 09 Sep 2021 20:36 by LesNewell.
09 Sep 2021 20:29 #238411
by LesNewell
The previous owner attempted to make a new rear panhard rod, with 'interesting' results. I have no major issues with a fabricated panhard rod but if you're going to do it, at least try to do it right. I don't know what the bushes were off but they only had a 8mm hole and bolt instead of the original 10mm. That doesn't inspire confidence.
The rod itself seems to have been made from two pieces of U section door runner welded together in the middle!
Not sure if I will make a new panhard or buy a second hand one. Anyone in Devon with a spare rear panhard?
10 Sep 2021 07:19 #238419
by Keithy
Replied by Keithy on topic Another green laner build
You look to be having fun and have the job in hand......A chap called Wayne Thompson is probably the nearest Jimny breaker to you.... Or J999PRE aka James Priestley can post one too.
10 Sep 2021 09:12 #238421
by LesNewell
Thanks for the names of possible sources for a replacement panhard.
- Thank you received: 1999
10 Sep 2021 09:46 #238422
Replied by Lambert on topic Another green laner build
Good to see another one saved from the scrap.
Time to create page: 0.383 seconds
