Re:Rear diskbrake conversion
13 May 2020 05:39 - 13 May 2020 05:40 #222188 by Riccy
Replied by Riccy on topic Re:Rear diskbrake conversion
I would undo the bolt holding the cable to the chassis to allow you to get it together. You might find by putting that bracket at a different angle helps (it can rotate once undone a bit). You are probably right about it being the huge axle droop causing the problem.
The caliper bracket should rest on the torx screw. With it how it is its like having the handbrake on a little all the time. Will wear pads fast and slow the car.
Last edit: 13 May 2020 05:40 by Riccy. Reason: spelling
13 May 2020 08:50 - 13 May 2020 18:20 #222193 by HUN
Replied by HUN on topic Re:Rear diskbrake conversion
Riccy wrote: I would undo the bolt holding the cable to the chassis to allow you to get it together. You might find by putting that bracket at a different angle helps (it can rotate once undone a bit). You are probably right about it being the huge axle droop causing the problem.
Correct me if I'm wrong but when the actuator/'caliper bracket' is taken off from the caliper then there is no braking force on the brake pads, right? Because I just simply took off and put back in a different angle. It seems to me the actuator/caliper bracket is spring loaded (?) and you would only put the brakes on if you're working against the spring by pulling the bracket, right? So by changing the relative position/angle between the braket and the threaded stud should work? I'm not a mechanic hence asking.
It would be good to know why there is a torx screw and what is it for? Acting like a bump stop?
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Last edit: 13 May 2020 18:20 by HUN.
Time to create page: 0.065 seconds
