Re:The Rat Trap
- Keirravn
04 May 2019 13:27 #207284
by Keirravn
Replied by Keirravn on topic The Rat Trap
Less car to paint anyway
- stiffsteve204me
04 May 2019 18:00 #207299
by stiffsteve204me
:laugh: :laugh: :laugh:
Steve.
Replied by stiffsteve204me on topic The Rat Trap
Keirravn wrote: Less car to paint anyway
Steve.
- Keirravn
11 May 2019 07:46 #207714
by Keirravn
Had a loud transmission whine so decided my first attempt to cure it should be a full driveline fluid change. I'd noticed when doing the CV some milky oil on the driveshaft anyway.
All very easy nothing stuck. Front diff was half full of just water. As I loosened the drain plug pure water started dripping out.
Also helpful but probably obvious tip - gearbox oil will pour out the filler hole if the front of the car is raised. DOH.
- Keirravn
11 May 2019 07:48 - 11 May 2019 07:48 #207716
by Keirravn
Whilst having a nosy in prep for the job I noticed the rear engine/gearbox mount had split so also replaced that.
I've gone from loud transmission whine on acceleration to 0 unusual noise
I suspect the transmission was going out of alignment and causing the noise as the transfer gearbox and rear diff oils all looked ok
Last edit: 11 May 2019 07:48 by Keirravn.
- Keirravn
29 Jun 2019 17:42 - 29 Jun 2019 17:44 #210440
by Keirravn
Last edit: 29 Jun 2019 17:44 by Keirravn.
- Thank you received: 1998
30 Jun 2019 04:53 #210450
Replied by Lambert on topic The Rat Trap
Nice bit of lateral thought that, plenty of pree made elements to just fasten together. Like that a lot!
The following user(s) said Thank You: Keirravn
Time to create page: 0.234 seconds
