Re:The Rat Trap
  • Keirravn
08 Mar 2019 09:54 #204300 by Keirravn
Replied by Keirravn on topic The Rat Trap
I'm reluctant to spend money guessing is the only thing. I'd be much happier with a code!
08 Mar 2019 12:00 #204304 by Max Headroom
Replied by Max Headroom on topic The Rat Trap
Totally with you on that!
I reset mine several times by simply disconnecting the battery, but each time I reset it, it would remain off for shorter periods. It finally started to come back on very quickly - within a mile or so of setting off.
I eventually gave in and cx'd the damned thing
The following user(s) said Thank You: Keirravn
  • Keirravn
08 Mar 2019 13:50 #204307 by Keirravn
Max Headroom wrote: Totally with you on that!
What's CX? I originally thought you meant changed but now I'm not so sure?
Mines comes back right away sadly
08 Mar 2019 17:14 - 08 Mar 2019 17:15 #204313 by Max Headroom
Sorry - aviation engineering yuckspeak - I use it at work every day and its a habit.
cx = change and cx'd = changed.
You were absolutely correct! :cheer:
Last edit: 08 Mar 2019 17:15 by Max Headroom.
  • Keirravn
09 Mar 2019 09:56 #204342 by Keirravn
Replied by Keirravn on topic Re:The Rat Trap
Max Headroom wrote: Sorry - aviation engineering yuckspeak - I use it at work every day and its a habit.
Got ya! Ha ha
  • Keirravn
11 Mar 2019 22:54 - 11 Mar 2019 22:55 #204473 by Keirravn
Not much progress to report. I've been having my head nipped about the time spent on the Jimny so had to leave it alone a few days :p
I did get all the tail lights working! All electronics now good other than potentially that obd. I'm borrowing a proper reader on Monday so will take it from there.
Kingpin bearings have arrived and I'll order a CV tomorrow and fit it all next weekend if time and weather suits.
Since all my welding (that I know is needed anyway) is done and all my electrical gremlins (I believe) sorted I was able to pop the interior back in which made it feel like a car again :)
I also sent away the forms to get the V5 and declare it sorn. I decided to be brave and register the colour as green ...
Here's my daughter (the wee one) and the neighbors kid getting their first seat in the Jimny. My daughter peed on the driver's seat about 4 minutes after I fitted it ...
Last edit: 11 Mar 2019 22:55 by Keirravn.
