G13bb to g16b engine conversion
1 year 6 months ago - 1 year 6 months ago #260223 by yakuza
You can reuse your G13 cylinder head.
depending on the actual year of 98 baleno it might have the coil packs and similar ignition as your Jimnys.
some also change the cam over from the g13's to make it "simpler".
But most easy is to use a donor with the same ignition system and swap over the signal ring on the cams from the g13 over to the g16 wich is what I did. (not my car)
Last edit: 1 year 6 months ago by yakuza.
1 year 6 months ago #260230 by greg
Bonjour ok car mon g16b l'anneau d'allumage 11 dents et mon g13bb anneaux 2 dents le changer aucun soucis mais quel repère prendre ?
1 year 6 months ago #260231 by yakuza
www.finn.no/70316191
I sell these here in Norway.
Sadly Norwegian postage is so expensive they cannot be sent abroad.
1 year 6 months ago #260244 by greg
Vous pouvez me renseigner pour le calage de l'anneau ?
Time to create page: 0.085 seconds
