Turbo Jimny
08 Oct 2016 05:46 #173264 by Lambert
Replied by Lambert on topic Turbo Jimny
Nooooooo the orange vents.have gone! Boo hiss.
08 Oct 2016 20:59 #173284 by Keithy
Replied by Keithy on topic Turbo Jimny
11/60 wrote: Nooooooo the orange vents.have gone! Boo hiss.
I can only apologise :D
Decided to put the 6 speed lexus box in the scrap pile today..I can live with 5...only have one or two projects before my next jimny related one.
Clearing some space in the shop over the next few weeks so I can fit more stuff in.
  • Tom1357
11 Oct 2016 11:07 #173358 by Tom1357
Replied by Tom1357 on topic Turbo Jimny
Would it be possible to install a turbo on a G13bb without altering fueling? As in, aftermarket ecu etc
I've been thinking of this, then found your post, and it's brilliant to see someone who's done it!
I thought I could make my own manifold, get a turbo of something small engined, I was thinking 1.6hdi type turbo, which I think is similar to the 1544 you've gone for.
Manifold made myself, second hand turbo, used intercooler and pipework, should be a very cheap way of some extra ponies :)
Obviously more air would mean more fuel necessary, but would the standard ECU be able to compensate and be sufficient for a low boost setup?
I only ask, ask mechanically I'm mildly capable, but the whole altering fueling and mapping, I am not. And it would keep it cheaper if I didn't have to.
11 Oct 2016 11:29 #173359 by Keithy
I saw a thread on difflock where someone fitted a turbo and only other thing he fitted was a rising rate fuel pressure regulator....With a 1:1 fpr it only injects the same amount of fuel so I can't see how that works...and have'nt got round to asking him how it gives more fuel.
Have a look for dwr I think online....who sell a "complete" kit for the G13B
Sadly I could'nt figure a way around the fuelling so had to do it the ECU way.
Talk appears now and then regarding remapping the original ecu but never a mounts to anything.
I was beaten through the lights this morning.....I need teaction control next ::dry::
Megasquirt is the way I went....very happy with it.
  • Tom1357
11 Oct 2016 11:51 #173360 by Tom1357
Right OK, so definitely a no go without altering fueling? As in it can't figure it out itself using the MAF/MAP or something?
I'll search those people you mentioned :)
11 Oct 2016 22:25 #173406 by Keithy
Standard jimny map/ecu has no idea what to do with pressure Tom....I did toy with "lying" to the ecu with a resistor engaged by a pressure switch to tell it to put the choke on....Not controllable so went with the megasquirt....If you like soldering you could do it a lot cheaper than I did.....but I don't see too good at close range.......Possibly you could control the whole thing for under £400 by getting it in kit form from diyautotune.com.....i bought mine from Phil Ringwood at extraefi.co.uk
Beware the 14.7 wideband lambda controller.....mine fell apart due to the housing being made on a 3d printer.....if I'd known that's what it was made of I'd have been more gentle with it.....It got replaced by an Innovate mtx....fantastic piece of kit!
Any questions on the installation just ask away.
Time to create page: 0.580 seconds
