Turbo Jimny
07 May 2017 18:17 #181016
by Keithy
Replied by Keithy on topic Turbo Jimny
Still waiting on cash and time on the SSS engine......so I've been getting on with other projects.
So after spending almost £3K building a vacuum forming machine.....finally getting stuff organised.
Ran a few test pieces off....made quite a bit of scrap plastic too!
One thing that's bothered me about the Jimny is the half assed rear wheel centres....Not any more....I finally got around to those.
New bodykit will be fitted to the silver Jimny over the next 2 weeks.....along with other stuff.
07 May 2017 19:47 #181028
Replied by jackonlyjack on topic Turbo Jimny
looking good matey
Jack
Jack
08 May 2017 06:11 #181035
Replied by Daniel30 on topic Turbo Jimny
Brilliant!!
- Millen
15 Oct 2017 07:48 #185243
by Millen
Replied by Millen on topic Turbo Jimny
Hey Keithy, nice project thread you got here, just read it through.
Please have some patience if you already mentioned something of what I'm about to ask. It's about the 1,3 turbo engine you ran.
So Garrett GT1544 with 0.38ar.
Did you change the compression with a thicker headgasket or so, or did you run it with original compresssion?
Added fuel pressure?
Injectors?
What exactly was the engine setup before you switched to 1,6?
Pictures of exhaust plumbing would be nice to see.
Best Regards
Mattias Fröberg
Injectors?
Best Regards
Mattias Fröberg
15 Oct 2017 08:05 #185246
by Keithy
Hi Mattias, The 1.3 used the standard 9.5:1 compression....no detonation even on cheap petrol.
I used a rising rate fuel pressure regulator after blanking the end of the original fuel rail.
I used the Liana injectors......only ever got to 53% usage so probably the standard 1.3 injectors would have been fine.
It ran @25PSI for 8000 miles before terminal conrod snappage
I have to say I never checked the condition of the 1.3 I used and after it was stripped it became apparent to me
that maybe it tolerated the 25PSI as it was worn out and had less than the original CR.....I'll admit to not caring if it had
blown up earlier as I figured engines are one of the cheaper parts to replace
So prior to the M16A fitment the engine was standard.
I'll get some pictures of the manifold later for you......it's made using sch 10 SS 304 fittings and a section of 304 tube to mate to the original exhaust.
15 Oct 2017 15:16 #185252
by Keithy
Just noticed a lot of the imgur etc pictures have gone missing......I may have to start posting images to my own server and get away from other peoples services.....can't even remember what the images were now!
Time to create page: 0.205 seconds
