Turbo Jimny
23 Sep 2016 23:03 #172742 by Keithy
Replied by Keithy on topic Turbo Jimny
Busta wrote: Few more questions....
Did you make the exhaust manifold?
What is the turbo from?
Have you thought about a bigger air box, or even an open filter? It has been suggested in the past that the standard air box is small to the point of being restrictive, even for the standard engine.
Hey Busta, Yes I made the exhaust manifold using sch10 tube(if I remember correct...I still have some left to check on this) A cast manifold can be had on ebay from a swift M series.....although they invert the turbo....and somebody put a chassis in the way on the Jimny.
The turbo is a Garrett GT1544 with 0.38ar as fitted to various sub 1.6l cars.
As regards the airbox....I've seen the reports of the size issues between various Suzuki air boxes for different capacities...it would appear in actuality that the Jimny airbox has enough capacity to allow plenty through....normal atmos+17 psi inlet pressure=enough?
I still have the pea shooter exhaust and cat installed......it's plenty powerful enough for traffic light racing and laning as it is :D
The following user(s) said Thank You: Busta, Lambert
24 Sep 2016 06:11 #172751 by Lambert
Replied by Lambert on topic Turbo Jimny
Hmmm. I am in the similar position to you with regards to the justification of the expense on what is ultimately a company car. I need a plan. Thank you for the info.
24 Sep 2016 08:55 #172756 by Busta
Replied by Busta on topic Turbo Jimny
Surely it doesn't need an intercooler that big though? By over-sizing it aren't you increasing lag?
24 Sep 2016 08:58 #172757 by Keithy
11/60 wrote: Hmmm. I am in the similar position to you with regards to the justification of the expense on what is ultimately a company car. I need a plan. Thank you for the info.
Good luck with that matey! :D I usually wait until it's my significant others idea :whistle:
@Busta, Sch10s 304 stainless lr90 elbows all welded onto the original Jimny exhaust flange...still got the egr in operation too.
Anyone know what the "power" indicator lamp was for in the dash?
It's set to light up under boost now......need a recording of J Clarkson shouting power to finish that part off :laugh:
24 Sep 2016 09:02 #172758 by Busta
Surely it doesn't need an intercooler that big though? By over-sizing it aren't you increasing lag? I don't know the maths but a small one that neatly fits the lower opening in the bumper must be enough.
24 Sep 2016 09:13 #172760 by Busta
Keithy wrote: Anyone know what the "power" indicator lamp was for in the dash?
B) Very cool!
Time to create page: 0.341 seconds
