Turbo Jimny
- MadsV
15 Oct 2017 19:17 #185257
by MadsV
Replied by MadsV on topic Re:Turbo Jimny
I’d like photos
been thinking of converting g16b for years now..
15 Oct 2017 19:20 #185258
by Keithy
Mine's the M16 Swift Sport engine Mads
Replied by Keithy on topic Re:Turbo Jimny
I was driving the wife's vitara today.....it's the G16B......I wouldn't botherMadsV wrote: I’d like photos
- MadsV
15 Oct 2017 20:20 #185260
by MadsV
Was thinking g16b turbo yes, got the engine laying already. Hard(expensive) getting the swift sport engine in Norway! Are you running without the turbo now?
15 Oct 2017 20:24 #185261
by Keithy
I am....it's better than the 1.3 but....once you have a taste of the precious!MadsV wrote: Was thinking g16b turbo yes, got the engine laying already. Hard(expensive) getting the swift sport engine in Norway! Are you running without the turbo now?
- Millen
16 Oct 2017 06:40 #185263
by Millen
Replied by Millen on topic Re:Turbo Jimny
Don't know how many percent the original ones use when maxed with original setting, it seems like a good idea to go bigger if a rise of fuelpressure is not enought.
Keeping them injectors under 80% could be a good rule of thumb.
Would be interesting to know if the rods should be able to handle more torque, if everything is in good condition and well balanced.
25PSI is quite much for not lowering compression I guess. Maybe cometic make thicker steel headgaskets for these.
Did the head stay in place or did you experience any lift there?
That turboconversion must have made he Jimny quite quick and responsive with that compression.
When it comes to the 1.6, have you compared weight of all parts that goes with it to the 1.3?
16 Oct 2017 07:21 #185265
by Keithy
Replied by Keithy on topic Turbo Jimny
I doubt the standard rods will withstand even gentle boost for long.....oh so skinny!
I bought 9.0:1 wiseco 78.5mm pistons and K1 500hp rods....so the 1.6 will be fine I think.
Weight will be slightly more due to crank and rod weight....negligible really.
It was a wild ride....zero lag and revved like a mad thing gone mad.
I sent you a pm
I sent you a pm
Time to create page: 0.210 seconds
