Project Sink or Swim
  • ZukracerV6
27 Mar 2016 10:24 #164418 by ZukracerV6
Replied by ZukracerV6 on topic Project Sink or Swim
Things are moving again! I have been computer less the last few months and trying to upload posts and photos via the phone is hard work!
The engine is fitted along with the radiator, cooling lines, heat exchangers (oil and water). I have had to modify a few parts in order to fit the air conditioning system to the project.
Remote oil filter adapter fitted with lines, that go to the heat exchanger and oil cooler. The engine and gear box fit in the hull as complete unit. Although the clutch has a low milage I have fitted a new clutch and throw out bearing.
Engine being lowered into hull
In order to get the engine into the hull, I have had to modify and extend the engine hoist to get the reach! The tyre acts as a counter balance!
  • ZukracerV6
27 Mar 2016 10:34 #164419 by ZukracerV6
Engine in place
Oil and engine coolant connections to the heat exchanger that is mounted underneath the hull
Engine oil cooler and fan in new modified position (normally sits in front of radiator)
All radiators and fans in position
  • Daniel30
27 Mar 2016 11:26 #164424 by Daniel30
Replied by Daniel30 on topic Project Sink or Swim
Brilliant looking really good
  • V-350
27 Mar 2016 16:30 #164447 by V-350
Replied by V-350 on topic Project Sink or Swim
Thank you!! Hope to see more pictures of the build - if possible!
There is this website of Hans Rosloot
www.amphibiousvehicle.net/myamphib/calm-...r/calm-water-04.html
He bought a 2nd hand (low milage, factory build) Mariner and found a lot of things wrong with it.
For instance on the hoses for the cooling.
www.amphibiousvehicle.net/myamphib/high-...r/high-water-02.html
"The old hose reads hydro 16 bar that is a water hose, a hydraulic hose has 200 bar written on it side.
If I try to bend them sharp they will crack. The new one reads Petrol - Oil 25 bar and it is nice soft rubber that will easily bend. I DO NOT HAVE 40 years experience in building cars, but this I know:
Oil and cheap hoses do not go together".
You should go through the lot of the pages to prevent the same problems as on his car.
  • V-350
26 May 2016 19:24 #167531 by V-350
Any chance for an update? Pictures?
  • ZukracerV6
01 Jul 2016 18:09 #169399 by ZukracerV6
A few updates! I have had the last week of work and have managed to be able to spend a good for quality hours working on the project this week!
The pedal box, accelerator and all cables have been fitted, along with the remote oil cooler and lines. I have also fitted the exsaust system, man that was hard work! The manifold and cat have been modiefied to all fit in the engine bay and space is very tight! I have also spent a lot of time insulating all of the engine bay and manifold.
The rear prop is also fitted (pics to follow) which was a real pain, as the access to the bolts attaching the prop to the transfer case is via the prop tunnel under the hull. Everything is hard work access wise due to the hull!
Time to create page: 1.139 seconds
