Suzuki Jimny Falconer Edition
  • the_goshawker
19 Feb 2015 18:43 #138480 by the_goshawker
Replied by the_goshawker on topic Suzuki Jimny Falconer Edition
Forgot to say I cut the jack holder out and will be putting this under the front seat. Also does anyone know where i can get the metal plug grommet things that are a bit bigger than a £2 coin. Ta :unsure:
  • Paul_sterling
20 Feb 2015 08:36 #138564 by Paul_sterling
Replied by Paul_sterling on topic Suzuki Jimny Falconer Edition
I wonder if its worthwhile fitting washers between the carrier and the door, that way there is a gap between them, so less likely to trap muck/damp in there?
I've not done it myself on either Vits or Disco, but just occurred to me when you raised the issue.
Paul.
  • the_goshawker
20 Feb 2015 19:21 #138606 by the_goshawker
I think thats a good idea paul ;)
  • jim
21 Feb 2015 20:52 - 21 Feb 2015 20:58 #138742 by jim
Replied by jim on topic Suzuki Jimny Falconer Edition
You must now have the most rot free jimny boot in the UK :)
Halfords do a selection of rubber grommets.
It may be a waste of time but I was thinking about leaving a moisture bag in the Jack recess.
Last edit: 21 Feb 2015 20:58 by jim.
  • gusthegorilla
22 Feb 2015 12:00 #138777 by gusthegorilla
Replied by gusthegorilla on topic Suzuki Jimny Falconer Edition
[quote=
[/quote]
I tried this once, Jim and it worked well for a short while, but then you have to be careful because when the collected moisture reacts with the crystals it turns to a weak acid (or alkaline, I forget which) and this kind of defeats the object unless you keep it all contained in some way!!
  • jim
22 Feb 2015 15:50 #138808 by jim
I didn't know that thanks.
Time to create page: 0.205 seconds
