  • darthloachie
23 Jun 2014 16:07 #118430 by darthloachie
Replied by darthloachie on topic Dave's (Bits4Vits) Jimny 'laner Build...
mlines wrote: How about some storage boxes fitted over the wheel arch???
we've got the ARB compressor on the left wheelarch and an entrenching tool on the right :)
[IMG
[IMG
The topic has been locked.
  • Bits4Vits
26 Jun 2014 09:49 - 26 Jun 2014 09:54 #118671 by Bits4Vits
Replied by Bits4Vits on topic Dave's (Bits4Vits) Jimny 'laner Build...
Bit more yesterday...
Almost finished the switch panel (still needs wiring yet though!) added another switch for the inside rear worklight on the rollhoop... and have also ordered two "push-to-make" switches, one blue one for a 'flash' button for the front LED lightbar (rather than having to flick the aircraft switch on and off), and one red one for a couple of louder horns (whilst still retaining the Jimny's cute "peep peep" horn ;) )
Mini CB has arrived to sit in the ashtray's space too...
Rear Panhard relocation bracket fitted, FTS from Taiwan, via JimnyBits...
Rockwatt Rocklobster box fed a tablespoon of Moly Grease...
... and then 900ml of EP140 thickish oil, my local oil supplier said it was for "older / low tech vehicles" (Cheeky! ;) )
Then got the box swapped in and under the car -
- mounted on JimnyBits rubber bush and bolt stack mounts...
and sorted out the shifter by cutting a small piece off the transmission tunnel and bending the stick a bit -
Due to the extra throw forward for the two-wheel-drive-low option that Rockwatt has also done on the box for me -
Then, to my amazement... Errr, I shouldn't have expected any less, but, I was still amazed... when selecting two-wheel-drive-low (which I assumed to be a workaround / bodge to merely disconnect the front propshaft)... in actual effect the "4WD" light goes off AND the front vacuum-operated free wheeling hubs actually disengage too... I was surprised to find this out during testing, I assumed the front prop would be 'dis-connected' from drive in the transfer box, but I didn't expect that the hubs would disengage too... this is more than I could of hoped for... my goal is to have a vehicle that has the utmost road driving manners (that a Jimny can have :unsure: ), so although it's lifted, by virtue of the Rockwatt Rocklobster transfer-box and the averagely sized 235/75/15 tyres, it should have a normal driving style on the road to get to / between the greenlanes, until I get to go offroad, and then with the flick of a couple of switches (compressor and then rear ARB) the rear axle will lock up, and the selection of four-wheel-drive (high or low) through the transfer box lever will then also activate the vacuum hubs which will connect the front Calmini LSD* (robbed out of my old Vitara) and should, with the aid of the super-low crawler "Rockwatt Rocklobster" box, give the little trucklet fantastic traction off-road, from the driver's seat (waterproof bucket) without having to get out and switch free-wheel-hubs in and out!
* This (LSD) took a step closer too, as Rob Storr (another engineering god!) emailed me to say the 26 spline front shafts and heavy duty CVs were ready, so I've paid for them and they'll be winging their way over soon, to fit in the LSD in the front axle... eventually, Phase Two that... with the rear winch... Phase One is to get it ready enough to go 'laning in the Lake District again the third Sunday in July with the rest of the guys... all in Jimnys! B)
Awesome... just needs the props bolting in now then... only I discovered the new-old-stock one I got off eBay is a 410 smaller splined at the gearbox end than a Samurai one, and so won't fit... To the rescue once again, Rockwatt has stuck one in the post to me... Superstar! B)
Last edit: 26 Jun 2014 09:54 by Bits4Vits.
  • Bits4Vits
26 Jun 2014 15:37 #118689 by Bits4Vits
With the ORA recently announcing they are stopping making Jimny parts, I thought it pertinent to buy the last-but-one set of their heavy duty rear axle to radius arm mounts from the BigJimny store... I don't need them yet, but best to have a set sat on the shelf in the garage for if and when I do...! As the stock ones look very thin!
www.bigjimny.com/store/index.php?_a=product&product_id=182
Last set anyone?!
  • O.R.A
26 Jun 2014 16:32 - 26 Jun 2014 16:35 #118694 by O.R.A
Replied by O.R.A on topic Dave's (Bits4Vits) Jimny 'laner Build...
Dave we're not saying we'll never make a Jimny part ever again, we still have a great deal of stock on the self... and if anyone ever wishes to order any particular products we'd still be happy to manufacture them to order within reason.
We're just simply stopping listing Jimny products online as off-the shelf parts, as we are finding that keeping up with batch production as well as running the other side of our business is very hard to manage and doesn't really work together very efficiently.
O.R.A
Last edit: 26 Jun 2014 16:35 by O.R.A.
  • Bits4Vits
26 Jun 2014 16:39 #118697 by Bits4Vits
ORA wrote:
IMPORTANT NEWS ABOUT O.R.A.
As many of you will already know we started out in business many years ago specializing primarily in Suzuki off-road parts & accessories, as well as building a vast array of competition off-road vehicles.
After many years of running both the fabrication & Suzuki parts manufacturing in conjunction with each other, sadly the day has come where we feel we need to chose one direction to fully focus our efforts on.
It is with a very heavy heart that we announce will no longer be manufacturing Suzuki specific off-road parts, as we have chosen to focus our business in the builder/fabrication direction of the industry.
We feel that the custom fabrication and off-road racing side of the industry is where we really excel and we are able to offer unique services that not many other off-road companies in Europe are able to offer.
Here @ O.R.A we have in house CAD designers, fully equipped workshop facilities with experienced fabricators that are able to build anything to suit your requirements, and because we are in complete control of our builds under one roof this also gives us great turn-around times and the best customer service and product you will find.
We have a reasonable amount of remaining Suzuki Jimny parts in stock, these are now being offered at discounted prices. But once stock is gone they are gone, so don't miss out!
We would also be happy to hear from any persons who may be interested in purchasing our Suzuki Jimny parts business as a going concern. Genuine inquiries only please, we will not sell individual drawings/designs. this is an offer for the whole Jimny parts manufacturing business only.
I must have misunderstood the above then? :blink:
  • O.R.A
26 Jun 2014 17:00 #118700 by O.R.A
Nope you read it correctly, "but" as with many of our older designs and products we have always been happy to manufacture special requests to order.
O.R.A
Time to create page: 0.289 seconds
