Daily on road use
  • iloveics
15 Jan 2014 18:24 - 15 Jan 2014 18:30 #100712 by iloveics
Replied by iloveics on topic Daily on road use
If you have standard panhard rods don't bother sorting out the steering if you plan on changing them, you'll just have to do it again. Panhard rods stop sideways movement of the axle, one end is attached to the chassis and the other the axle. (If you didn't know)
Also for radius arms, I use Rhino Rays. for 3" lift but they are not suitable for a 4".
www.rhinorays.co.uk/suspension.htm
They are £120 an arm with bushes, so they are the cheapest on the market by a long way.
People slate Ray, but he was helpful to deal with, the arms fit perfectly and plenty strong with the "I" section.
As for road handling, you should have wheel spacers or offset wheels with that sort of lift/tyre combination.
Possibly a steering damper, which gives you more steering "feel" and takes out wheel wobble.
Last edit: 15 Jan 2014 18:30 by iloveics.
16 Jan 2014 06:55 #100762 by robs5230
Replied by robs5230 on topic Daily on road use
Jenksdogg wrote: Steering wheel is about 4-5pm in a straight line. Is it worth getting aligned? The caster bushes Ive already got apparently and are fairly new and offset. So I guess I may need to get some caster arms? The brake lines are new and extended. I just want to make it a bit safer handling on road. Thanks for helping guys any of you near Worcester or hereford want to show me what the hell I've got and what I'm doing lol?
if you have caster corrected bushes you shouldn't need the arms. have a look at your front diff, if it looks vertical then the caster correction should be good. if the top of the diff tilts noticeably to the front of the car it may need caster correction. if it looks like the caster is corrected i'd have a look at more basic things , tracking , tyre pressures , then maybe wheel spacers to add a bit of stability and width.
standard jimny - for now
  • Jenksdogg
16 Jan 2014 07:12 #100765 by Jenksdogg
Replied by Jenksdogg on topic Daily on road use
Thanks rob you don't wanna pop ova and teach me a thing or two do you? I know how to drive a jeep bit mechanics I'm useless
16 Jan 2014 16:55 #100779 by robs5230
Jenksdogg wrote: Thanks rob you don't wanna pop ova and teach me a thing or two do you? I know how to drive a jeep bit mechanics I'm useless
please don't disregard other posters, some with more jimny experience than me, but my car has recently had the cc bushes done and the angle of the front diff has been corrected.
  • Jenksdogg
17 Jan 2014 12:58 #100863 by Jenksdogg
jimny getting the tracking and wheel alignment done today so will go from there.
tempted to try and swap my wheels and tyres for some black modulars an A/Ts if anyone interested?
Time to create page: 0.196 seconds
