Daily on road use
  • jimnyjack
15 Jan 2014 13:28 #100679 by jimnyjack
Replied by jimnyjack on topic Daily on road use
If you get arms you can put the standard bushes in i think mate so you dont need the both. ;)
  • jonesyba420
15 Jan 2014 13:34 #100680 by jonesyba420
Replied by jonesyba420 on topic Daily on road use
yea i dont think you need caster corrected bushes AND arms, the arms are carter corrected so id think normal bushes will be fine. dont the arms come with bushes? ring ORA they will help further.
probably pointless giving it to a garage, specially as we're all pretty certain its a caster issue.
anything over a 2"lift needs caster correction, the 2.5" ORA lift kit comes with CC bushes, CC arms are recomended for 3"+ lifts.
  • jimnyjack
15 Jan 2014 13:42 #100682 by jimnyjack
No the bushes are around an extra £230 for a full set i think mate.
Wish they did come with it though that would be nice!
  • jonesyba420
15 Jan 2014 14:15 - 15 Jan 2014 14:34 #100685 by jonesyba420
4x CC radius arms from ORA = £780
full set super pro bush set = £368.40 (im sure cheaper bushes are available)
tota = £1148.40
prices subject to P&P.
not a cheap issue to rectify :ohmy:
i personaly would have a really good look under your truck to try figure out what exactly has been fitted before you go ahead and buy anything.
another option (which id probably do in your situation) is to purchase this kit . i think this comes with everything needed APART from bushes. the chances are whoever lifted your jimny didnt do any of the other things to make it drive properly.you can then sell the lift kit thats on your truck currently to make abit of the money back ;) ;)
EDIT: just read abit more on the ORA site and you can use factory bushes in the CC arms.
i think you may still need other things for a 3"+ lift, longer/adjustable panhard rods are needed to realign the axles with the chassis, extended brake lines (you probably have these tho), prop spacer, need to re position the brake load valve thingy.
once everything is sorted it'll be seriously capable ;)
Last edit: 15 Jan 2014 14:34 by jonesyba420.
  • jonesyba420
15 Jan 2014 14:22 #100686 by jonesyba420
Jenksdogg wrote: How do I know if I got or need correction bushes and castor arms etc.
only just noticed this and that no one seems to have answered it, i think if the caster is out the steering wont self center.if im wrong im sure someone will correct me ;)
  • Jenksdogg
15 Jan 2014 17:03 #100703 by Jenksdogg
Replied by Jenksdogg on topic Daily on road use
Steering wheel is about 4-5pm in a straight line. Is it worth getting aligned? The caster bushes Ive already got apparently and are fairly new and offset. So I guess I may need to get some caster arms? The brake lines are new and extended. I just want to make it a bit safer handling on road. Thanks for helping guys any of you near Worcester or hereford want to show me what the hell I've got and what I'm doing lol?
Time to create page: 0.169 seconds
