Sound system
- Jus jimny
04 Oct 2012 19:26 #49494
by Jus jimny
Replied by Jus jimny on topic Sound system
Thanks peop's for all your advice, is all sorted now once I read what Vaxxi wrote I had a good look around behind the dash today, and the harness that I put in was now connected to one that was their already! Once I took my one out it all works how it should.
Now I have got that sorted I just need to sort out the sh#ty sound it makes, I have mocked up a cardboard box shaped to house a 6x9 in, under each front seat, watch this space.
- VAXXi
04 Oct 2012 20:31 #49510
by VAXXi
Replied by VAXXi on topic Sound system
And if you put the speakers under the seat, where will the moved air go ? your buttocks ? :laugh: under seat install only works for a subwoofer, but that' a bit different than regular speakers.
The stock speakers' location is not *that* terrible; just put in good 4" speakers on the front and back (the rears can fit 5.25" with new mounting holes), put in a bit of sound proofing, insulate the speakers' lip to sit tight against the sheet metal and sound can be quite satisfying.
- Jus jimny
04 Oct 2012 21:24 #49515
by Jus jimny
Have you tried putting speakers under the seat then, their should be enough room for air movement, how much room dose it need? I'v just put a new set of 4" alpine type e in the front and have a set of 6x9 jbl's from my boy racer days, the alpines sound fine but have no bass at all, which is all I would like.
- Tadpole
05 Oct 2012 09:33 - 05 Oct 2012 09:34 #49528
by Tadpole
Replied by Tadpole on topic Sound system
Hijack for a linked related question if I may :blush:
Since acquiring my (standard) 2003 Jimny I only have sound from the passenger side speaker.
Can you please tell me if the feed to the speakers runs from the radio connection independently?
If this is the case I’ll start my search there, thanks guys
Last edit: 05 Oct 2012 09:34 by Tadpole.
- VAXXi
05 Oct 2012 12:14 - 05 Oct 2012 12:15 #49537
by VAXXi
Yes it does. It's blue/black + blue to passenger side and black/red+red to driver side coming from head unit connector (might be swapped on RHD, manual doesn't say that though).
Last edit: 05 Oct 2012 12:15 by VAXXi.
- Tadpole
05 Oct 2012 12:24 #49538
by Tadpole
Many thanks I'll take a look see what's going on, back to topic ....
VAXXi wrote: Yes it does. It's blue/black + blue to passenger side and black/red+red to driver side coming from head unit connector (might be swapped on RHD, manual doesn't say that though).
Time to create page: 0.173 seconds
