Sound system
- Jus jimny
01 Oct 2012 22:58 #49305
by Jus jimny
Sound system was created by Jus jimny
Am new to the Jimny world and loving it so far, I have got an O2 2002 and would like to upgrade the stereo, not sure were to find the threads for any advice?
Have put in an old Pioneer I had from my boy racer days. The harness I had for it fitted straight in, how ever the dashboard clock is now permently on, the stereo it's self is on all the time and dose not need the ignition on but the weirdest thing of all is that when I disconnect the aerial cable all of the above go off???
Hope that makes sense, if so has anyone got any idea what is going on, will it be ok to run the clock all the time or will it be to much of a drain on the battery? Not to bothered about having to turn the stereo on & off all the time, maybe I might need to get the correct harness if so will it be the same or maybe mod the one I have "yadder yadder yadder"
- Skinhead
01 Oct 2012 23:15 #49306
by Skinhead
Replied by Skinhead on topic Sound system
Not sure about the clock or why the aerial does that but pull the stereo out and try swapping the red and yellow wires around, hope this helps
- Jus jimny
01 Oct 2012 23:26 #49307
by Jus jimny
Replied by Jus jimny on topic Sound system
Ok will give that a go tomorrow thanks, probly not a good idea to go rooting around with car stereo's at this time of night?
- Skinhead
01 Oct 2012 23:48 #49309
by Skinhead
Thats when i learnt lol
- Jus jimny
01 Oct 2012 23:59 #49310
by Jus jimny
Just quickly, do you think that the clock will be alright being on all the time, as in drain the battery or get to hot and start melting wires together?!?!
- supergaz
02 Oct 2012 15:20 #49341
by supergaz
Replied by supergaz on topic Sound system
The aerial will be acting as an earth. It sounds to me like you have the live and ignition live the wrong way around, if I remember correctly on ISO connectors the red is permanent and orange is ignition live, they will both have fuses and the wires can be switched over on the fuse holder.
Time to create page: 0.252 seconds
