My 2011 Rebuild
25 Sep 2015 11:11 #152528 by Jezz
Replied by Jezz on topic My 2011 Rebuild
Must of been fitted by Jeremy Clarkson then. :laugh:
It's been fettled just a tad.
25 Sep 2015 16:48 #152536 by jackonlyjack
Replied by jackonlyjack on topic My 2011 Rebuild
No eBay APP ID and/or Cert ID defined in Kunena configurationthe crazy fitter guy at work suggest this type fitting :unsure:
25 Sep 2015 18:18 #152539 by mlines
Replied by mlines on topic My 2011 Rebuild
Thanks for that, it looks the part but I think the internal threads are wrong. I will have to research into threads a bit more
25 Sep 2015 20:52 #152558 by Keithy
Replied by Keithy on topic My 2011 Rebuild
Anyone got a lathe near you?
An adaptor would be easy enough to make as a permanent repair.....
what size is the hole in the casting? I could make the adaptor if no one nearby will/wants to rob.
My arb's were terminated differently to what I see in the picture iirc <tx spk there :D
26 Sep 2015 06:34 #152570 by mlines
Replied by mlines on topic Re:My 2011 Rebuild
Keithy, I don't know anyone with a lathe. However the current plan is that I have ordered the correct tap tool and will try tapping a thread into the casing. This is on the assumption that it was never tapped originally. If it takes a thread then I can buy a new adaptor from Devon 4x4.
Thanks for the offer and if it doesn't take a thread then I may be looking for your help.
Sent from my Nexus 5 using Tapatalk
  • Rockwatt
26 Sep 2015 23:49 #152601 by Rockwatt
Replied by Rockwatt on topic My 2011 Rebuild
Drill and tap to 3/8 bsp and get a 3\8 to 1/4 reducing bush and fit a new standard fitting. Or use a bush but with some push fit fittings on the inside and outside
3/8 bush and 2x 1/4 bsp to 5mm push fit
Time to create page: 0.258 seconds
