The end times are upon us.
- Thank you received: 2004
23 Jan 2025 07:10 #259193
The end times are upon us. was created by Lambert
Not at all jimny related but I'm just trying to buy some nuts and bolts and for reasons I can't fathom I can't find a physical supply of m12 bolts in 8.8 grade in a quantity of less than 50. I need 4. Yes I can get them off the Internet and yes I'm sure in other less tourist reliant towns there's probably loads of little shops with buckets full of them I could just rummage through. If this is what a post industrial society looks like, I'm not a fan! Shop local they say, support your community and businesses they say, how if no one sells what I want to buy?
23 Jan 2025 07:15 #259194
Replied by Lambert on topic The end times are upon us.
Oh and threaded bar only seems to come in 1 metre lengths now for some reason?
23 Jan 2025 07:21 #259196
Replied by Soeley on topic The end times are upon us.
Sometimes it can be very hard to shop local, I think Amazon has a big part to play in it as it is often the quickest and easiest way. It will only get worse with Temu and Shein. I do draw the line at those two though!
23 Jan 2025 07:33 #259197
But the Internet comes with it's own problem namely lead time and shipping costs and could I really rely on a courier being able to deliver a single length of m6 Threaded bar in anything resembling a straight and usable condition?
23 Jan 2025 08:23 #259199
Replied by yakuza on topic The end times are upon us.
Cant buy M10 or 12 bolts in quantities more than 4-6-8-ish here so it is the oppsite problem.
Was building a stable from galvanized steel beams and girders and the swedish kit came with all the wrong nuts and bolts. Had to buy 10 packs of bolts insted of a large case of 50 pcs..
And yesterday I had to buy 1m of copper pipe to fix a leak and only needed 20cm. Wich was a good thing as I cut the first pipe too short.
Still got the 60cm for the next leak.
26 Jan 2025 15:45 - 26 Jan 2025 15:46 #259242
by Gadget
Replied by Gadget on topic The end times are upon us.
Edit: just realised that you meant a brick and mortar shop, but still, link might come in handy!
@lambert - this places sells M12 8.8 bolts individually, I bought some M12 galvanised 8.8 bolts from them back in the summer.
www.orbitalfasteners.co.uk/
Last edit: 26 Jan 2025 15:46 by Gadget.
Time to create page: 0.182 seconds
