Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Subcategories from this category:
SJ Rebuild
31/12/07 - Dennis' Jimny - UPDATED!
Dennis has sent in some new pictures of some extreme green laning! Looks like it might have needed a bit more than T-Cut to clean it afterwards.
  10045 Hits
27/11/07 - Andy's Jimny
Some of the modification articles on this site have been sent in by Andy. The current specification of his Jimny is:
  18700 Hits
15/07/08 - Daves Jimny
Those of you who are regular to this site wil recognise this one. Originally posted here as "Madmicks" Jimny it has been sold to Dave and moved north of the border to Scotland. Dave has added in some more pictures as well.  Its a year 2000 model with:
  14688 Hits
27/11/07 - Rear Wheel Carrier
Andy has kindly sent in some pictures of his rear wheel carrier as a follow on to my article on fitting the spare wheel (see: Rear Tyre Mount).
The age old problem is that larger tyres need off-settting from the door to stop them fouling the bumper and permitting the rear door to close properly. Andy has designed and built a "Swing Away" carrier that not only solves this problem but also deals with the weight issue of the wheel. In my solution the weight is carried by the rear door and based on past experience with the SJ series this will eventually lead to "door sag". In Andy's solution the weight is carried by the rear bumper......
  15956 Hits
28/11/07 - Hand Throttle
Again,thanks to Andy for this one. Most off-roading involves low speed maneuvoring and control. This can be difficult to achieve on the foot throttle, particularly when winching out of a problem. With winching you need to achieve a slow steady rotation off the wheels or a steady charging current from the alternator to assist the batteries, therefore steady control of the throttle is required....
  18707 Hits
