Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
05/01/12 - BigJimny's LittleJimny!
As I am currently without a car and James will be learning to drive later this year, we have bought a Jimny for him to learn in and then have as his first car, so say hullo to LittleJimny.
  13314 Hits
15/12/11 - Rebuilding the Axle
So you may recall that in preparing for my replacement lift we discovered some major damage to the rear axle.
  16335 Hits
24/11/11 - Removing the shock
So its slowly onwards with the work. Those of you who what the forum will have seen me comment on the problem of corroded bolts and difficult access. The most challenging in a suspension upgrade is the bolt at the top of the rear shocks. This is left in the mud and muck and suffers the constant pounding of the suspension. Typically its rusted in place and the inner steel bush sleeve is cold welded to the bolt through the impact.
When I first "tested" the bolt on the drivers side, there was no movement, so I have been soaking it every day with various penetrating oils. Tonight I decided to "go for it!"
  16248 Hits
Aargh - It all goes wrong
So with my BigJimny Lift Kit coming together and my Offroad Armory Spring Clamps I set out tonight to start the winter rebuild. First a quick look at the ORA Spring Clamp Kit I thought I would do it properly, with Spring Compressors, it was a bit fiddly to get them in and I had to play around with the optimum stretch on the spring to get them in. I...
  9332 Hits
Tags:
22/10/11 - Replacing the Wing
Those of you who have seen my Jimny may recall that it has a dented front wing. This has been like this since I bought it, but despite it being a large dent it is actually quite hard to see.
  11827 Hits
