Font size: + –
1 minute reading time (207 words)
04/02/11 - Rear Panhard Rod - updated
So I went out and had another look tonight. This is the starting point with the Panhard Rod mount fouling the Rear Caliper.....
Therefore I played around with the adjustment in the rod. By measuring how far the tyres stuck out each side I got the axle just about central. I then checked the Brake Caliper....
Hmm, not bad. Picture actually makes it look worse as its hard to see the exact alignment of the two. I think it will be all subject to a test a Tong where I will have trailered the Jimny so any wear problems on the hose will not be a danger on the way home.
If you want to feature your Jimny or modification suggestion on this website send some pictures and information to Martin (This email address is being protected from spambots. You need JavaScript enabled to view it.) in any layout/format and I will add it to the site
BigJimny@Tong - Were you there??
03/02/11 - Rear Panhard Rod
