Oh No ! - Where has the metal gone !
So in fitting the front winch I have been looking for a location for the second battery. Playing around with a battery showed that there is not really enough space under the bonnet. The problem is height rather than length. Anyway, the rear tray in the boot is an attractive location for the battery and it puts more weight over the rear wheels.
My car was converted to take a rear winch and this was fitted in the rear tray with a hole for the cable exit. This was letting water in now that the winch is not fitted so in order to fit the battery I needed to fill the hole.......
  9638 Hits
Changing the Brake Pads
We had abandoned our trip to the TV4x4 Club day at Speen due to a horrible grinding noise that could be heard and felt through the brake pedal. The usual reason for this is the front pads are worn. So here is a simple guide to this straight forward job.
  10097 Hits
Wiring!
Fitting the spare tyre on the outside of the car meant I have to move the number plate and the number plate lights. Bad move! - it turns out that the wiring at the rear of the car is dreadful. The wiring is domestic mains cable (huge amounts of it with the spare cable coiled inside the rear door) passing through the rear door rubbers into the car. The wires are joined into the loom with spade connectors protected by Duct Tape and cable tied along the bumper. The water/mud has got into the connections and its all a complete mess and completely rotted out.
  10468 Hits
Brakes! - Damn Brakes!
One thing I loved about the Sj was its all round disc brake conversion. This meant that I no longer had to mess around cleaning out brake drums.
  11175 Hits
4wd Drive Switch
When I first purchased the Jimny it had a problem where the 4wd switch did not appear to work. This switch is located on the Transfer Box and tells the Computer that 4 wheel drive has been selected which then vacuum locks the front wheel hubs.
  12068 Hits
