First-time owner - help with radio please
- Thank you received: 142
Flatfendweller wrote: That looks like the beastie - thanks very much
Any ideas:-
What is AS? (top right)
Is TA the traffic announcement?
Is there a way of making it stick to a station and auto-find the strongest signal?
Is there a clock function on this model?
If I find a station I like and just hold down a pre-set number, should it then be saved under that number (It doesn't seem to want to do this)
I'm guessing this is code protected, but don't know and don't have a code.
Really appreciate your help.
AS is auto store press and hold for 2 secs or longer and the station is stored to your preset channel eg 1 etc.
If you have a disp button (top right) press until you get a clock display then adjust the up/down arrows for time.
TA is indeed traffic announcement.
AF alternative frequency. If you switch this on (should say AF on the display) this should change to a stronger frequency if available from that station(all this is only on FM)
- Flatfendweller
- Visitor
- Zee Zee Top
- Visitor
- Flatfendweller
- Visitor
- Flatfendweller
- Visitor
- Flatfendweller
- Visitor
Still fades in a bit, but I think that is an aerial issue and when I have some pennies I think I will replace both the radio (really want a clock!) and the aerial but these things will have to wait.
Anyway - as a newbie and not very technically minded, just want to say thanks to everyone here for being so helpul
There are posts on here about this!!
- Thank you received: 260
gilburton wrote: Note that the Jimny has a non standard double din surround limiting your choice of alternatives.
Yes I came across this today when I wanted to get the radio out and ended up taking off the complete front including clock and ciggy lighter socket. But mine has a Pioneer radio fitted even so and that is fairly common sizing or is it??
- Flatfendweller
- Visitor
To be honest, I can't afford to change it anyway but as and whe I can I will be asking for help, that's for sure.
I hope I've posted a pic of the rubbish radio in my Jimny-and a rubbish picture of the Jimny to go with it.
Flatfendweller wrote: I have read that there are problems replacing the radio - saw a few threads about it.
Ooooh yes, that's very different from my dash.
- Zee Zee Top
- Visitor
Before giving up try a set of new speakers.
By the way your Jimny looks good.
