BigJimnyMeet 2024
Dave’s long-term Lil’Bugga Buggy Build
- Dirtbird
- Visitor
17 Aug 2021 19:23 #237677
by Dirtbird
Replied by Dirtbird on topic Dave’s long-term Lil’Bugga Buggy Build
This is them Blitzworld BuggiesLOL! Yes, exact same seat?! Weird!
Yes, remember that from back in the days of Difflock. fella spent a fortune on it... racking my brain for his name...?
- Thank you received: 923
19 Aug 2021 04:46 #237707
Replied by X8GGY on topic Dave’s long-term Lil’Bugga Buggy Build
Baloo - Alan Chambers, that was him!
Engine and transmission... (Suzuki) motorbike engine I'm hoping... already have the reverse kit in my parts pile -
See below, but front engined...
Dirtbird - think small rock buggy, like these as inspiration...
But obviously on the cheap / a lot simpler...
- Baloo
- Visitor
20 Aug 2021 17:02 - 20 Aug 2021 17:02 #237743
by Baloo
Replied by Baloo on topic Dave’s long-term Lil’Bugga Buggy Build
hi Dave
that yellow buggy is super cool i could easily be persuaded not to use a jimny chassis and build one like that lol, only reason for the jimny chassis was to keep it road legal but i could live with trailering it around
are you definitely going to narrow your axles ? are you planning on using jimny coil springs ?
Last edit: 20 Aug 2021 17:02 by Baloo.
- Dirtbird
- Visitor
21 Aug 2021 15:54 #237760
by Dirtbird
- Dirtbird
- Visitor
21 Aug 2021 15:56 #237761
by Dirtbird
This is going to work out well as I've got a second set of Jimny parts, going to try and get the transnational back together first.
22 Aug 2021 10:25 - 22 Aug 2021 10:28 #237777
Yes, Jimny coil springs that will dislocate, due to super long shocks...
4x new standard Jimny front springs, 4x JimnyBits “Black Raptor” brand +5″ rear Grand Vitara gas shock absorbers, and four spring clamps.I don’t want too much lift with the buggy being short and narrow, but it needs to have plenty of articulation, so the springs will dislocate at the top, and be held in place by the spring clamps which are attached to the spring cups on the axles.The shocks are 29″ at full droop and 15″ compressed, so that gives me plenty to play with when the suspension is setup during the build…
Lots of unsprung weight (axles wheels and tyres) and a small light buggy on the top
I looked at air shocks, rod end links, etc, etc, but this is just a simple cheap build again using easily sourced repair parts, to keep me sane in the garage...
Yes, determined to use to narrowed front axles, I want a small one seater buggy, and it has to be about the size mentioned above to be able to get both buggys in my garage...hi Dave
Last edit: 22 Aug 2021 10:28 by X8GGY.
- Dirtbird
- Visitor
22 Aug 2021 12:11 #237785
by Dirtbird
- Baloo
- Visitor
22 Aug 2021 13:36 #237787
by Baloo
Hi Dave
Well it seems like you have given this a lot of thought and worked it all out, cant wait for you to start assembling , the long vitara shocks look interesting i might have to investigate those, can I buy longer than stock jimny springs and if so where from ?
Andy
Andy
22 Aug 2021 19:36 #237792
Longer springs? - www.jimnybits.com/jimny/suspension.html
I'm not saying it's the best way to do it, just that it fits in with my budget, limited facilities and skills...Hi Dave
Andy
22 Aug 2021 19:41 #237793
Loving the egg yellowGoing to add a little yellow, tipping my hat to your build Dave.
- Dirtbird
- Visitor
22 Aug 2021 21:27 #237800
by Dirtbird
- Baloo
- Visitor
23 Aug 2021 09:52 - 23 Aug 2021 09:54 #237807
by Baloo
Andy
Hi Dave what your doing all looks good to me, in an ideal world your radius arms want to be further out away from the diff but then your going to run into clearance issues when on full lock, I don't think having them so close together will be an issue for a rock buggy , be different if it was a highway machine and you were steaming through corners at 70 mph
I was asking about longer springs as I need to sort out what I'm doing, l like the idea of standard jimny suspension just with longer springs and shocks, I see there is some plus 4" springs and shocks on jimny bits for £279 which I might go for, undecided at the moment
Last edit: 23 Aug 2021 09:54 by Baloo.
Time to create page: 0.147 seconds
