Dave’s long-term Lil’Bugga Buggy Build
- Thank you received: 923
The front (front) axle is now nearly done, to match the rear (front) axle.
I hope to finish it off on Sunday and then paint one of them. Then I can reassemble it with all new parts, clean, paint and add a pair of radius arms, mount the wheels and tyres, and then start mocking up the transfer box and props (as the front and back will be virtually the same), and that will lead to the initial chassis design - starting with the chassis rails, and developing the rest as we go...
- Thank you received: 1765
- Baloo
- Visitor
Unlike my rich friend Baloo on here I couldn't afford to send them for media blasting... I had a wire brush attachment in my angle grinder!
So the axle tube needs 13" / 33cm cut out here'ish -
Lots more photos in the blog linked above...
More soon...! lol its tenner to have an axle blasted, i would rather drive down to the blasters and pay the man a tenner than spend £10 on wire brushes lol anyway good to see you making progress, it all looks good to me, i could easily get talked into a single seat buggy it appeals to me, i have collected some bits i might lay them out on the floor and see if it works, will be 2wd though and a car engine, keep up the good work cheers Andy
lilbugga.wordpress.com/
I particularly like this one…
lilbugga.wordpress.com/2022/04/09/dislocating-spring-bump/
Dave
That’s my original sketch above (for the benefit of others): so you mean a smaller helper spring in here -
That looks plausible too!
iI’ll add that to the blog and credit you with idea!
Keeping it clean… pressure washer and add more grease through the grease nipple and smear some over the exposed piston inner tube between outings…
It's a bit long but it demonstrates that you need traction even with all the articulation. That or you need a Jimny.
bid gone in
looking at stock suspension -
the cone with the bump stop on the bottom inside the spring looks to be 2”+3” long, and these are about 5.5” long, so should compress to 2” to 3” ?
(ones is 6.5” long but Mr.Angry will soon sort that
And they’re 2.25” internal diameter so will slip nicely over some 2” OD seamless tube roll cage off cuts I’ve got lying round, which will make the outer tube of the ‘pistons’ I’ve proposed above…
- Thank you received: 178
Thanks Mark, but the above are the proposed helper springs to go above the standard new (4 fronts) Jimny springs I’ve already got ready -I have got a set of stock springs off my 2011 jimny for sale
[img][url]https://www.bigjimny.com/media/kunena/attachments/29464/0A1DABBC-2522-4CFA-8FA1-433A35FD9A3E.jpeg[/url][/img]
With some JimnyBits own-brand “Black Raptor” rear GeeVee shocks which are 29” open and 15” closed so 14” of articulation feasibly possible, but probably not in practice! LOL
