- Thank you received: 923
theoldseacaptain wrote: Recently bought the same calipers - they came out of the box with no lubricant at all on the slider pins, so may be worth checking yours if you haven’t already greased them up!
Yes, noticed that "theoldseacaptain"
Thanks!
maverick wrote: I've always considered getting a PRESS for home usage ... If you find a decent one that's suitable for our Rear Shafts and Front Hubs, let me know (maybe they can reduce cost for TWO???)
Normally, Mr. A. Grinder comes out to grind off the ABS Collar and Bearing, but only today I have found a local Community project called Shedheads. They have my two duff Rear Shafts with worn out bearings and decent ABS Collars "pressed" on. I asked them if they can heat up the AB collar and tap it off (then its re-useable) and maybe het up duff bearing and get that off too??? Then it'll be a trip to my friendly garage (they have a press) to pay them £10 a shaft to press bearing and ABS collar back on??? But IF i had a press, that would save me about £50 a year ...
From memory when we last discussed this, Martin has something like this -
www.machinemart.co.uk/p/clarke-csa10ep-1...nomy-hydraulic-floo/
So we'd dangle the rear shaft through the hole and then press the shaft down onto the bearing / ABS Collar ?
My local garage do it with a length of roll cage tube they pinched from me...! The tube goes over the shaft and the collar gets beaten home with a BFH (Big F... Hammer!)
I'll ask Santa for a press this year
- Thank you received: 116
And also testing the Autool OBD2 reader I’ll write a little review on that in the tech section...
- Thank you received: 1761
- Thank you received: 333
You really should fasten your dashboard bolts!S200KYS wrote:
Not sure what the dashboard might get up to when it's loose like that though...
- Bits4Vits
- Visitor
They are all front springs from a Mercedes W124 230 E Saloon car
REMEMBER that they gave me 5" of lift on a heavy Jimny, they are right for my application, but may NOT be right for yours... I was planning on cutting them down to suit but as it happens they all fitted on - front and rear - with no cutting or modifications to any other suspension components - but again, that's for MY application.
- Bits4Vits
- Visitor
Here's the blog including all Brett's (Maverick) videos -
greenlaning.blog/2018/05/30/greenlaning-...nbighshire-27-05-18/
Enjoy!
- Bits4Vits
- Visitor
Look at the articulation of S200KYS at the start of this video -
