Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Rear wheel bearings
regal2250_IMGA0242
So a miracle occurred and I did some more work on my Jimny today. First of all I repaired the ARB air locker tube that had been damaged. The threads had been pulled out in the brass mounting so I had purchased a repair kit and refitted the fitting.
You can see the original damage in this article - https://www.bigjimny.com/index.php/bigjimny-blog/problems/entry/812-arb-air-line-repair and the photos below show the new parts alongside the old.
  11223 Hits
