Re:My 01 Jimny, another Norwegian
  • Venter
  • Visitor
  • Visitor
03 Jan 2019 11:41 #199932 by Venter
Replied by Venter on topic My 01 Jimny, another Norwegian
I'll be following the brake upgrade MadsV, I'm getting tired of having to refurb mine every year due to stuck calipers etc, so looking at what can be done to improve them
  • MadsV
  • Visitor
  • Visitor
03 Jan 2019 11:44 #199933 by MadsV
Replied by MadsV on topic My 01 Jimny, another Norwegian
Yes same here. I refurbished the right one last january, now its the left one thats hanging. There is some good threads on the forum about this upgrade also.
03 Jan 2019 11:52 - 03 Jan 2019 11:53 #199934 by yakuza
I am doing my brakes this weekend I hope. Got the correct vented discs with 108mm center hole (ABS-models) before christmas but haven't had the time to swap the parts yet. Calipers and hangers have been lying in the shelf for years as they where supposedly going on my SJ. But better to start using them sooner i guess.
Also changing the rear master cylinders and shoes as the handbrake hangs up in reverse. All sticky and gooey in there from leakage and dirt.
Last edit: 03 Jan 2019 11:53 by yakuza.
  • OlaGB
  • Visitor
  • Visitor
03 Jan 2019 13:45 #199946 by OlaGB
Replied by OlaGB on topic My 01 Jimny, another Norwegian
What brake parts are you guys using? And are discs/pistons bigger than stock, by how much?
  • MadsV
  • Visitor
  • Visitor
03 Jan 2019 18:15 #199972 by MadsV
Ordered complete front brake kit for diesel jimny at brakes.com with ebc greenstuff pads. And ordered calipers from Meca, brand FTE, for 5 door vitara g16b.
I can post links with the parts if you like, will probably make a bigger post with details when i’m fitting it
  • OlaGB
  • Visitor
  • Visitor
03 Jan 2019 18:30 #199974 by OlaGB
MadsV wrote: Ordered complete front brake kit for diesel jimny at brakes.com with ebc greenstuff pads. And ordered calipers from Meca, brand FTE, for 5 door vitara g16b.
Aha.. No need for details right now, but it`ll be interesting to read youre post afterwards!
Brakes sure could be better than stock.. Lets hope youre brake bias still will be ok, or are you doing rear too?
  • MadsV
  • Visitor
  • Visitor
03 Jan 2019 18:33 #199975 by MadsV
Eventually the rear also, i have all i need but the calipers so not long hopefully!
  • MadsV
  • Visitor
  • Visitor
04 Jan 2019 20:51 #200030 by MadsV
Calipers arrived today. I will paint the new parts before installing them. Ordered the brake kit from ebc today also, so i have to find a weekend to do the brakes and the kingpin bearings on the left and the seal on the right
06 Jan 2019 22:54 #200101 by yakuza
I did not bother to paint my new stuff as usual... Should have.
From memory, the vitara caliper piston is 52mm diameter and the SJ where 46mm. I have no idea what diameter the jimny is.
  • MadsV
  • Visitor
  • Visitor
10 Jan 2019 22:01 #200386 by MadsV
Did a solid red bmw today, so got some red on the calipers at the same time. Etch primer, sealer, two coats red and two coats clear. Should give some protection :lol:
Brake discs and pads should be here next week so hope to change them next weekend
11 Jan 2019 05:12 #200396 by Lambert
Very colour coordinated, will it handle the heat ok?
  • MadsV
  • Visitor
  • Visitor
11 Jan 2019 06:36 #200403 by MadsV
Thats a good question, i dont know really. Will have to wait and see
Time to create page: 0.218 seconds
