Re:The Jimny of the Yakuza
- Thank you received: 329
Sent fra min E5823 via Tapatalk
sizes are 46mm for jim and 50mm for liana. both are cable (not drive-by-wire, which the swift one my engine came with was).
Riccy.
So far so good. Not broken anything and still got my office fingers intact.
Loosened servo pump and ac, exhaust manifold and all wires on that side. Started on intake side but that's where most of the hoses and wires is. Forgot to pull the fuel pump fuse while the car was running so haven't disconnected fuel lines yet. I am going to put clamps on them. Generator is loose and all on front end. Will be tight around the ac lines..
Leaving this for tonight to go spend some time with the family, but will be back tomorrow morning.
Tonight I sandblasted all the steel bits needed to change over to the 1.6VVT....then powdercoated them.
On the pipe to the rear of the waterpump spray some penetrating oil into the join and wiggle it side to side and it comes away easier.
My 08 Liana VVT throttle body is also 46mm so no point in swapping these.Riccy wrote: The throttle body i used was from an 04 liana 1.6 and it was a straight swap, no pipe issues, no idle valve to swap. it does now idle at lower RPM, and i haven't had a long test run in it from a cold start yet to see what its like, but initially its a definite improvement on the jimny TB.
Riccy.
Hooking up two wrenches-trick.. Jimny engine still in the car.
First picture, longest tube is jimny, other short one is M16 Liana.
Motor started up nicely first attempt.
Got a engine warning lamp, fault code says HO2 Sensor no. 1. (lambda)
Could be I have yanked wires too much.
Tips:
Have all service items ready, coolant, oil, filter.. Clutch? Check donor engine for leaks, easier to fix when engine is out.
Silicone gasket, loctite.
Remove both manifolds from the car. Makes everything easier imo.
Check donor engine flange for pins.
Use the donor fuel injectors, rest from jimny.
Maybe I'll do a write up later. ☺️
I had similar gearbox flange pin problems. How did you get on with the coolant output from the water pump? i couldnt swap the jimny's output plastic thing as studs didnt line up, so ended up with a flexi hose to connect A to B. Be interesting to know for what engines are easier to swap than others?
I found after more test driving that it was a bit over-geared with the 235 tyres on, but i can live with it (unlike the 1.3 with them tyres, which couldnt do 70). I do have an earlier t-box (stick type) and am after some earlier diffs, which will correct the gearing nearly exactly to the tyre size. Ive also got a full-on rocklobster t-box in the shed for when i fancy some bigger rubber
I find it is sitting at loud setting on the snorkel when doing 70 with the M16 (approx 3900rpm) so should be higher RPM (quieter) and 1st gear setting off feels like its straining the clutch a bit, hence the looking at gearing options. Im pretty good at the gearing calculations if you want to know more Low box is ok, but not low enough for any sort of rock crawling.
Riccy
I used the complete thermostat housing from the Jimny.....complete with plastic inlet......I did wonder which part you couldnt fit.....ergo the long hose?Riccy wrote: Great news!, and welcome to the (exclusive) M16 club
Riccy
