Expedition Jimny Project
- JerseyJimny
- Visitor
mudman wrote:
Decalwizard wrote: That will be ace Nico if you can pull it off, I was thinking of an ex-trailer tent as a base to work off..
I agree with you JJ the Nato hitch is the best by far. I thought of a sankey trailer to use also.
DW
you could try making your own version of the ozhitch
That just looks like two ends of a prop with the UJ with a trailer hitch welded to it
- PascalASR
- Visitor
Cheers! Pascal
- Decalwizard
- Visitor
Still got lots of goodies to bolt on the Jim yet, but it gets closer every day :woohoo:
Dw
- jimnyturbo
- Visitor
still loving mine, feels really big when your inside, and the engine sound a lot bigger than what it actually is.
- Decalwizard
- Visitor
I made two batons and covered them with carpet which sit in the recess of the tropicool cooler to lock it into position. The bottom will have strong Euro crates each side for cooking utensils etc and the other side will be food items..
- supergaz
- Visitor
Decalwizard wrote: This is what got my attention, KAP Suzuki do these as a modification using the rascal pickup bed. I was thinking of the rear end of a Jimny with axle and using the same bed.
Dw
It would tow like poo, it needs to be low and wide to be stable. Also using anything other than an approved 50mm ball hitch on a jimny is illegal. So no nato hitches or
ball and pin as these are also a no no on passenger cars.
- JerseyJimny
- Visitor
- Decalwizard
- Visitor
Dw
Hi Gaz
It was the actual Rascal Pickup Tub I was referring to, I was not going to run it as high as it is in the picture, I was thinking lower than a sankey trailer in height.
Dw
- Decalwizard
- Visitor
JerseyJimny wrote: Whats that fridge you have in the back there?
Its a Weaco Tropicool 35L
Tropicool TC35
DW
- JerseyJimny
- Visitor
I have orderd a weaco coolbox instead
- Decalwizard
- Visitor
DW
- JerseyJimny
- Visitor
Them things are brilliant
