SJ Transfer Boxes
14 Jan 2011 23:15 - 15 Jan 2011 09:28 #9675 by MigCooper
Replied by MigCooper on topic Re: SJ Transfer Boxes
vitara_mad wrote:
MigCooper wrote: I spent some time already looking at this and it seems that there is a lot of money to spend in this route ... :unsure: I think that to achieve a proper reduction you will need 2 transfer cases, one from a 413 and one from a 410 and then get then to a specialist to make one 1 of the 2.... from my calculations from what I can remember the 413 transfer case was 250 and the 410 was around 400 + plus the "magic work"
So after thinking a lot I think I will go for the (Product name removed at the request of the manufacturer). you can check them (Product name removed at the request of the manufacturer)].
Still one month to decide and then something will happen :evil:
you dont need to buy new transfer box's to get them made into a lobster box just get used ones it cost me £50 for both the 410 & 413 box & then £400 to get them made into a lobster box & the fitting kit only other thing i had to get was the prop shafts so all in it was about £500
or you could just buy everything already done inc the fitting kit & the lobster box from o.r.a or d&g tuning or they might even be more supplyers around
I would love that and will have another look arround as the (Product name removed at the request of the manufacturer) are arround 700 euros plus fitting and will be limited to that from that point on .... will check ora now
cheers
In the end I have around 700 euros to spend on parts and want the best option for this price...
Snorkel and plenty of rust to be treated :)
Last edit: 15 Jan 2011 09:28 by mlines.
14 Jan 2011 23:30 #9676 by MigCooper
Rob Butler mite have something to say to this :whistle:
15 Jan 2011 18:30 #9714 by Jamie
Replied by Jamie on topic Re: SJ Transfer Boxes
The main thing to look at when purchasing a kit is to how the gears have been cut and welded back together,
The right way is to drill and pin them then to weld them together, the welding needs
to be done right and the gear needs to be 100% square on the shaft.
The welding also needs to be high quality and not just any idiot with a Mig/Tig!!
Other than that you could build your own, new seals and bearings are not too expensive.
I have seen a few different kits around and some look a bit shoddy to me, if the mounting
kit and speedo converter look crap then just think of the gears inside doing all the
work!!!
I'm not going to publicaly recommend or slag off anyones boxs as the forums speak
for themselves....
Do a bit of trawling about and the good names crop up again and again
15 Jan 2011 19:29 #9719 by Jamie
You know what, i will add a bit more to my previous post..
I shopped around for ages looking at where to buy my lobster from, speaking to
people in the real world and finding out which were reliable and which were a bit
er well naff really!!
I wont be naming the ones i've heard bad things about, so after speaking to people
who compete and are using them in the harshest terrain 1 name just kept on cropping up,
i then spent a little more time trawling though forums looking up who had ben having
problems with gears coming apart, i wasnt too fussed about oil seals and bearings
as i count those as consumables it was mainly the gears as thats the crucial part!!
Luckily i went to Kirton a managed to get a look at a good kit, i then spoke to Rockwatt
and ordered my kit from him, for less money i recieved a realy good peice of kit
which came with a rockbucket to protect the box from impact, my own choice of drive
flanges, a nice pneumatic fitting and hose for the breather and the speedo drive
is a thing of beauty!!
I worked for an engineering company for around 10 years so i know what im looking
for in these kits and this one just looked the best both inside and out!!!!
this comes highly recommended by me and many others if you look around, i don't
think it was built in a shed though????
Also to add this has now done 8000 miles but ive changed the oil 3 times as i like to
keep it clean!!!
Pic's
Speedo drive
Lobster installed
Rockbucket
Lobster
  • vitara_mad
15 Jan 2011 21:14 #9726 by vitara_mad
Replied by vitara_mad on topic Re: SJ Transfer Boxes
i have the same the only differance is i made my own rockbucket
15 Jan 2011 21:15 #9727 by andyw
Replied by andyw on topic Re: SJ Transfer Boxes
Hi Jamie,
Glad you like yours B) , good bit of gear, been pleased with mine, just wish i'd have got around to it years ago lol. Rich did mine:woohoo:
Andy
Time to create page: 0.328 seconds
