Gen 3 - New tyres for my jimny
- alpinejimny13
18 Sep 2024 21:37 #257577
by alpinejimny13
Gen 3 - New tyres for my jimny was created by alpinejimny13
So the time has come to replace my Duelers (205.70.15) and I'm finding it quite tough to choose between a few options, so I call upon the infinite knowledge of the BigJimny™ Forums to help me decide, any tips are greatly appreciated. I'm hell bent on sticking with the stock size for mine as MPG is quite important to me, however as I said experience is appreciated.
I have a couple of options such as:
Conti Crosscontact AT (the one I'm currently looking at the moment)
Michelin LTX Force
GT Grabber AT3
And a few others. Thanks in advance!
Michelin LTX Force
GT Grabber AT3
- Thank you received: 437
18 Sep 2024 22:59 #257578
Replied by DrRobin on topic Gen 3 - New tyres for my jimny
Are you Duellers highway tread?
If they are then swapping to an AT tyre will increase fuel consumption a little as they tend to be heavier and have a higher rolling resistance.
If you don’t go off road, except the odd gravel track and most if not all of your miles are on tarmac, then you might as well stick with a highway tread, they will give you the best mpg, road holding/ride and stopping distance.
However, if you do go off road and want a bit more grip on the soft stuff then an AT tyre might be the answer, but it won’t be quite as good on-road.
Robin
Robin
- alpinejimny13
18 Sep 2024 23:09 #257580
by alpinejimny13
Replied by alpinejimny13 on topic Gen 3 - New tyres for my jimny
Forgot to add it to my op but its the AT thread.
- Thank you received: 1800
19 Sep 2024 04:54 #257583
Replied by Lambert on topic Gen 3 - New tyres for my jimny
Unless you are after a specialised tread pattern which is very limited for choice in 205.70 then anything you buy with a reputable brand name is going to be fine. The difference between them really is splitting hairs.
- Thank you received: 508
19 Sep 2024 06:07 #257584
Replied by Soeley on topic Gen 3 - New tyres for my jimny
Yokohama Geolander GO15 are a good A/T that are not too aggressive a tread and are not as heavy as some A/Ts.
They do them in 205/70/15, I have them in 195/80/15 which is the stock size for the Gen4 Jimny.
I have had no issues with these on or off road.
The following user(s) said Thank You: alpinejimny13
19 Sep 2024 07:56 #257585
Lambert’s right, there is little to choose between them, except some of the cheaper tyres age faster, so you start to see small cracks in the surface faster.
I had Yoko Geolandar (205/70r15) on my Gen 3 for a while, before swapping to Maxxis in a bigger size, they were a very good tyre for the money.
Robin
Robin
- Thank you received: 23
19 Sep 2024 13:29 - 19 Sep 2024 13:54 #257590
by Motacilla
Replied by Motacilla on topic Gen 3 - New tyres for my jimny
Hello alpine,
Since mileage is a concern for you, you will probably want to look at the weights of the tyres you are considering. You may be surprised at how much they can vary between types/brands.
For example, the Duellers in 195 are 22.9lbs each, while a Yokohama Geolandar in the same size is 27lbs -- and you would definitely notice an 18% increase in tyre weight.
That is just an example I had to hand, unfortunately I don't have figures for the three you mentioned. But you can find them online, and it is definitely worth consideration.
Let us know what you decide to go with!
And thanks for the nice pic
Last edit: 19 Sep 2024 13:54 by Motacilla.
- Thank you received: 661
19 Sep 2024 13:44 #257592
Replied by jackonlyjack on topic Gen 3 - New tyres for my jimny
Going for 205 75 15 will give you more road bias choice
- alpinejimny13
19 Sep 2024 14:48 #257593
by alpinejimny13
Here in Brazil there are actually LESS options for this size, definitely interesting though.
I like to travel a lot and the places I've been to before had some moderately hard tracks/obstacles to clear.
Also looking at the Kumho Road Venture A/T51s, they look very interesting, although they are a tad heavier than my Duellers. Thanks everyone for your replies!
20 Sep 2024 06:48 #257602
by Motacilla
You could also consider swopping wheels at the same time. A lighter rim could offset a heavier tyre.
For example, the standard steel rim for the Gen3/Gen4 weighs 19.2lbs, while the Gen4's factory alloy rim is only 15.4lbs each. An Oxxo Forrest(sic) aftermarket alloy wheel is just 13.7lbs!
From your photo it looks like you may already be running alloys, but it may be possible to find a lighter model of wheel, depending. Just a thought.
- Thank you received: 102
20 Sep 2024 12:18 #257605
by fordem
Be VERY careful with this approach - a heavier tyre has a negative impact on braking.
Replied by fordem on topic Gen 3 - New tyres for my jimny
20 Sep 2024 14:16 - 20 Sep 2024 14:18 #257608
by Motacilla
(Since he is changing away from the Dueller, any tyre Alpine chooses will be heavier than what he has now, so that decision has already been made.)
Right, I am saying that a lighter wheel will partly abate the effects (mileage, braking, handling) of a heavier tyre.
Last edit: 20 Sep 2024 14:18 by Motacilla.
Time to create page: 0.160 seconds
