Noises when steering in 4WD
So I’ve recently been hearing noises and they’re getting worse whenever I turn almost the maximum, I’d say anything above 70% steer.
I don’t know how to describe it but it sounds like something is grinding with ticking.
When I steer in 2WD it’s ok even when my lockers are on 4x4.
Any ideas? Thanks
- Thank you received: 1801
- Thank you received: 662
cos when it breaks you will struggle to turn making it almost impossible to drive home
- Thank you received: 458
The only other thing, are you running bigger tyres, they might be catching on the wheel arch, especially if like me the front bumper was pushed back after dropping in to a rut whilst off roading, usually the sound of a cv is different?
- rogerzilla
- Visitor
It being quieter with the hubs in 4x2 suggests the when the wheels are turning the cv joints they are not running on the worn parts of the joint balls.
The thing is that I have fixed hubs so they’re always on 4x4 and it makes noise only when I’m actually in 4WD but when the lever is on 2H and I steer it doesn’t make the noise even with the hubs locked
_________________________________
I believe its only the left one but I will lift both front wheels up and checkIs it coming from both wheels or just one?
Normal tyres, just bigger engine which I believe contributes to wearing CVs right?are you running bigger tyres
I heard it many times on asphalt, I’m not entirely sure about slippery surfaces, if I don’t hear it on slippery surface what does that mean?are you on a loose or slippery surface?
I see, hope I can find a CV joint without having to buy the whole rodadvise fixing it soon
Thanks everyone
- rogerzilla
- Visitor
You shouldn't be using 4WD on asphalt unless it's very slippy (snow/ice). It will make noises and cause difficulties with steering as you get windup between front and rear axles.
I see, I just wanted to test to see where it’s coming from, because I heard it first time while offroading so actually yes I just remembered that it does make the noise on slippery surfaces
- rogerzilla
- Visitor
- Thank you received: 415
Are the noises intermittent, connected to wheel revs, accelerating or braking or coasting?
Or in/out flexing?
Open diffs?
a "friend" of mine put a large cable tie on my drive shaft once. That ticked
That sound was so obvious so I had more or less determined what it was before I looked under the car
I recently also started hearing cracking noise sometimes when going in reverse in 4WD, but not always, not sure if it’s related
I’ll try replacing the CV joint and see how it goes, thanks
