Re:Re:Wandering on the Road
- Thank you received: 16
08 Dec 2023 19:32 #252748
by Phaeton
Wandering on the Road was created by Phaeton
Sorry for so many newbie questions, only been using the Jimny around the village but today had to go to the hospital & then later nipped back into town to go to Wickes. It wanders & tramlines quite noticeably, don't think it's a death wobble it's not that severe, but very noticeable, it was only MOT'd last week & the tester is a mate of my son's, so all the cars get a really good thorough going through, even if he doesn't fail them, he's been known to pass a car then deliver it back to me with the parts that need fitting on the passenger seat with the invoice
Anyway, spoke to him & he says the bearings, bushes etc. on the suspension are all good & there's no play, so what could it be, not checked tyre pressures today, (I thought I did last week). It's been lifted 2" but has not had the castor bushes fitted could that be a cause, is it also worth having the tracking checked. It's on Insa tyres not sure of the size,
08 Dec 2023 19:50 #252751
by jlines
Replied by jlines on topic Wandering on the Road
I would say it sounds normal for the Jimny. My lot Gen 2 to 4 both standard and modified all wander about on the road getting caught in the tramlines. Tire pressures can make a big difference in handling and I find the Jimny likes lower pressures. Roof racks also aren't great on Jimnys. Are they insa turbo mud terrains? If so they are a very aggressive tire on the road.
The following user(s) said Thank You: Phaeton
- Thank you received: 656
08 Dec 2023 19:51 #252752
Replied by jackonlyjack on topic Wandering on the Road
Jimny's do wander
Try not to fight it so hard it just makes you tired.
Doing castor correction bushes will make the steering feel a little better, also a steering damper a little more better
But it will always like to wander
08 Dec 2023 20:14 #252753
by Busta
Replied by Busta on topic Wandering on the Road
Definitely get the castor angle sorted. It's castor that gives the steering its stability and self-centering characteristics.
08 Dec 2023 20:14 #252754
by Phaeton
Replied by Phaeton on topic Wandering on the Road
Might try lowering the pressures, I think I put them up to the pressures on the B pillar, not sure if they are mud terrains, they don't look too aggressiveI would say it sounds normal for the Jimny. My lot Gen 2 to 4 both standard and modified all wander about on the road getting caught in the tramlines. Tire pressures can make a big difference in handling and I find the Jimny likes lower pressures. Roof racks also aren't great on Jimnys. Are they insa turbo mud terrains? If so they are a very aggressive tire on the road.
08 Dec 2023 20:17 #252755
by Phaeton
Never heard of a damper on a car, do you have any further information, it has power steering I take it it's not speed dependant less assist the faster you go?Jimny's do wander
08 Dec 2023 20:22 #252756
by Phaeton
Are these suitable as our host doesn't list them these are on Fleecebay but it won't let me post a link 186135115123 although I'm not sure I believe the spiel
"Fitment time - approx 10 min per bush - simply knocks in with a mallet"
- Thank you received: 434
08 Dec 2023 20:54 #252757
Replied by DrRobin on topic Wandering on the Road
Mine used to wander and it is not lifted. I always thought the steering was too light and fitted a steering damper, they are only about £80 as a kit (cheaper if you buy the bracket kit then get a cheaper damper off eBay), takes about 15 minutes to fit and transforms the car at 60mph.
I used to find on a long journey my arms would get tired compensating for the twitching steering going over uneven surface or due to wind, but now it is much less effort and I don’t notice the heavier steering at slow speed, even lock to lock.
The general advise for a lift seems to be get castor correctors as well.
Robin
Robin
08 Dec 2023 21:57 #252759
by Busta
Yes those will do the job. The 10 min doesn't include the time it takes to remove the old bushes...Are these suitable as our host doesn't list them these are on Fleecebay but it won't let me post a link 186135115123 although I'm not sure I believe the spiel
- Roger Fairclough
- Thank you received: 210
08 Dec 2023 22:20 #252761
by Roger Fairclough
Replied by Roger Fairclough on topic Wandering on the Road
It's a natural characteristic of beam axle cars with a steering box. There will always be a degree of slack in comparison to independent front suspension with a steering rack. Try a series 1 Land Rover, they had a mind of their own!
Roger
Roger
- Thank you received: 1797
09 Dec 2023 04:01 #252766
Replied by Lambert on topic Wandering on the Road
I too have a steering damper on my otherwise stock plus suspension and it makes Temeraire behave like a normal car in terms of directional stability, way nicer than Spare Jimny. I'm not saying you don't notice the solid axle ride but it definitely only goes where you point it.
09 Dec 2023 08:21 - 09 Dec 2023 13:43 #252767
If you can fabrication yourself my damper kit cost about 30 quid and a couple of hours
Use a Mk1 disco damper around 20 quid on ebay
Page 10 if you need an idea how to make one
In the link below my Jimny
Last edit: 09 Dec 2023 13:43 by jackonlyjack.
