Re:Re:Wandering on the Road
08 Dec 2023 20:22 #252756
by Phaeton
Replied by Phaeton on topic Wandering on the Road
Are these suitable as our host doesn't list them these are on Fleecebay but it won't let me post a link 186135115123 although I'm not sure I believe the spiel
"Fitment time - approx 10 min per bush - simply knocks in with a mallet"
- Thank you received: 550
08 Dec 2023 20:54 #252757
Replied by DrRobin on topic Wandering on the Road
Mine used to wander and it is not lifted. I always thought the steering was too light and fitted a steering damper, they are only about £80 as a kit (cheaper if you buy the bracket kit then get a cheaper damper off eBay), takes about 15 minutes to fit and transforms the car at 60mph.
I used to find on a long journey my arms would get tired compensating for the twitching steering going over uneven surface or due to wind, but now it is much less effort and I don’t notice the heavier steering at slow speed, even lock to lock.
The general advise for a lift seems to be get castor correctors as well.
Robin
Robin
The following user(s) said Thank You: Phaeton
08 Dec 2023 21:57 #252759
by Busta
Replied by Busta on topic Wandering on the Road
Yes those will do the job. The 10 min doesn't include the time it takes to remove the old bushes...Are these suitable as our host doesn't list them these are on Fleecebay but it won't let me post a link 186135115123 although I'm not sure I believe the spiel
- Roger Fairclough
- Thank you received: 211
08 Dec 2023 22:20 #252761
by Roger Fairclough
Replied by Roger Fairclough on topic Wandering on the Road
It's a natural characteristic of beam axle cars with a steering box. There will always be a degree of slack in comparison to independent front suspension with a steering rack. Try a series 1 Land Rover, they had a mind of their own!
Roger
Roger
- Thank you received: 1865
09 Dec 2023 04:01 #252766
Replied by Lambert on topic Wandering on the Road
I too have a steering damper on my otherwise stock plus suspension and it makes Temeraire behave like a normal car in terms of directional stability, way nicer than Spare Jimny. I'm not saying you don't notice the solid axle ride but it definitely only goes where you point it.
- Thank you received: 680
09 Dec 2023 08:21 - 09 Dec 2023 13:43 #252767
Replied by jackonlyjack on topic Wandering on the Road
If you can fabrication yourself my damper kit cost about 30 quid and a couple of hours
Use a Mk1 disco damper around 20 quid on ebay
Page 10 if you need an idea how to make one
In the link below my Jimny
Last edit: 09 Dec 2023 13:43 by jackonlyjack.
