BigJimnyMeet 2024
G series to M series motor swap
- Thank you received: 36
13 Jul 2020 12:00 #224990
by Old Neil
Replied by Old Neil on topic Re:G series to M series motor swap
I'm impressed with the amount modifications people on this forum have achievedKeithy wrote: Chassis is the same.....James has an M13A in his originally G series car.....turbo and intercooler fitted too it has a Megasquirt ECU controlling it.
Not sure if the intermediate propshaft is different.
Nothing is impossible.
- Probablynotfrank
- Visitor
13 Jul 2020 13:09 #224998
by Probablynotfrank
Replied by Probablynotfrank on topic Re:G series to M series motor swap
I'm planning something similar with a Vitara gearbox onto my M15a, as my R72 is on its last legs and I've got a Vitara gearbox and transfer box (with front output removed) sitting about.
14 Mar 2022 19:48 #242318
by steele
Replied by steele on topic G series to M series motor swap
Instead of starting a new thread I'll ask this here in the hopes of some insight! It's about the two engine types.
I don't need a gearbox but will need the engine to fit to it.
My 2004 Jimny needs a new engine to drop in, she has an M13A .
Can I buy ANY engine including the G series, and give them to mechanic to put in my Jimny or should I keep looking until I find the same year M13A?
They're so scarce in Ireland. I've found a G type and two others of different years. TIA
- Thank you received: 1761
15 Mar 2022 05:21 #242326
Replied by Lambert on topic G series to M series motor swap
It's definitely much easier to use a similar type even if it's a different year.
- Thank you received: 332
15 Mar 2022 06:28 #242327
Replied by yakuza on topic G series to M series motor swap
You will definatley need to get a m13a engine. the G will not fit. not only the gearbox but also the electronics and sensors will be a major headache.
However in Ireland there might be other Suzukis with the m13, m15 or m16-engine. More or less any non-VVT m13, m15 or m16 engine will do. My car has a Liana engine.
Time to create page: 0.092 seconds
