BigJimnyMeet 2024
Axles/Differentials
- Thank you received: 45
08 Jan 2019 19:40 #200196
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Axles/Differentials was created by HUN
Hi All.
My Jimny is from 2005. It has M13a VVT engine, R72 gearbox, ABS etc..
Can I fit axles/differentials from a donor Jimny from all year between 1998-2018 or just 2005 and later years? Can I use axle without ABS? Would it pass MOT?
Sorry for my daft questions.
Regards, Gabor
Regards, Gabor
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
08 Jan 2019 20:11 #200203
Replied by Riccy on topic Axles/Differentials
non VVT axles have different diff ratios, but the casings are the same otherwise. if you have ABS then you will need a donor casing from an abs vehicle. Would pass a UK MOT no problem.
08 Jan 2019 20:14 #200204
For example; I have 2007 vvt axle casings but the earlier non VVT diffs and have no issues swapping parts between them all.
- Thank you received: 1763
08 Jan 2019 20:14 #200205
Replied by Lambert on topic Axles/Differentials
Ideally you are better off with abs axles on an abs car as it's one of the few driving aids actually worth having. Also for the mot it's possible to remove the abs system completely and not get a failure but to have a constant abs warning light on is a failure. There is also the insurance cot notify who will undoubtedly increase the premium.
09 Jan 2019 03:59 #200220
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Replied by HUN on topic Axles/Differentials
Thanks for this info Guys!
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
12 Jan 2019 17:45 #200594
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
My current understanding of this subject based on what I could read here and heard from others:
Casing had been made either with ABS or without ABS in the past. I should fit only casing with ABS that's for sure.
After about 2004-2005 the engine was made either M13A non-VVT or M13A VVT.
All (M13A) casing size the same but non-VVT has different ratios. What does it mean? Lower or higher?
And what about axles made before 2004? Was all of them wihout ABS therefore those aren't for me?
How many different variant of axle can be found out there? Four or even more? I just cannot get it...
Educate me please...I feel confused.
Thank in advance.
Thank in advance.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
12 Jan 2019 18:05 #200595
OK then, Gearing calculation is the key here.
For the gearing avaliable by swapping different parts about see the wiki here.. www.bigjimny.com/mediawiki/index.php?tit...erential_information
and use that information with a website called 'grimjeeper' to compare the effects of changing any given part. www.grimmjeeper.com/gears.html
with enough work and parts it is possible to swap the gearbox, t-box and diffs between vvt and non vvt. its also possible to swap in a SJ t-box or a rocklobster box for really low drive
very versatile is the Jimny
12 Jan 2019 18:09 #200596
I realise that doesnt answer your question. Basically anything in the UK with ABS would have suitable donor axle casing from 2001 onwards.
To be certain I would ask for one from a hard top M13 engine'd model.
13 Jan 2019 07:01 #200615
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Thanks Riccy. I gonna have a proper look into those link.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
15 Jan 2019 13:48 #200791
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Ok then. Here is a quick question: would an 2004 ABS axle change my current gear ratio? I guess yes, because all engine before 2005 were non-VVT. Is it correct?
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
15 Jan 2019 18:28 #200813
The casing would, but the diff will be a 3.9, where you need a 4.3 to keep it the same. You could swap the diffs over, but that means removing the shafts.
The result would be to over-gear the car, making it slow to accelerate and cause clutch wear. You would also need to swap the front to the same ratio diff if you want to keep 4x4 ability.
15 Jan 2019 22:01 #200826
by Busta
Replied by Busta on topic Axles/Differentials
The question nobody has asked yet is what are you hoping to achieve? Are you just looking to replace a damaged axle or are you looking to alter the gearing?
If its the gearing you seek to change you only need to swap the diffs, not the entire axle. All the diffs are interchangeable, so you could buy some '98 diffs and fit them in a 2017 Jimny and vise versa.
