BigJimnyMeet 2024
Howling/vibrations after 4" suspension lift
- MattB12
- Visitor
12 Jul 2016 14:21 - 12 Jul 2016 14:54 #169918
by MattB12
Howling/vibrations after 4" suspension lift was created by MattB12
Hi guys, I've got a 2007 1.3 VVT Jimny. I've just fitted a 4" suspension lift with castor corrected arms all round, adjustable panhard rods and front prop spacer.
The axles 'look' to be centered and i still need to do the tracking. I'm running 205/75/15 tyres on 15x7 rims with the plan to fit 31's soon.
My problem is, when driving an aggressive vibration through the whole car can now be felt. It sounds like a howl and gets louder the faster I go. It feels like it's coming from the center of the car going back towards the rear.
It seems to be matched to road speed and not engine speed, if I push the clutch in at 30mph to drop the revs the noise and vibes are still there.
I've removed the rear prop and tried driving around on the front two and it became a lot less noticeable, in fact it felt like it disappeared. Put the prop back on and the vibes and noise come back.
If the axle is off center, even slightly, could it cause this?
I've read in another thread where the OP had a similar problem. They had to fit a rear prop spacer as well to cure it. For an 07 Jimny do you think a rear prop spacer is needed for a 4" lift?
Many thanks
Many thanks
Last edit: 12 Jul 2016 14:54 by MattB12.
- MattB12
- Visitor
12 Jul 2016 18:51 #169935
by MattB12
Replied by MattB12 on topic Howling/vibrations after 4" suspension lift
Whilst i'm trying to figure this out, would any harm come to driving around with the rear prop off in 4WD using the front?
- Thank you received: 923
12 Jul 2016 19:02 #169937
Replied by X8GGY on topic Howling/vibrations after 4" suspension lift
Have you still got the original transfer box and prop fitted then?...
I'm not sure, but I wouldn't have thought a standard rear prop (with the CV thing on the t-box end) would cope with a 4" lift?...
- viciouspenguin
- Visitor
12 Jul 2016 19:11 #169938
by viciouspenguin
Replied by viciouspenguin on topic Howling/vibrations after 4" suspension lift
It's too short and probably right at the limits of extension and about to pop out.
Use an SJ series front prop on the rear if I remember right.
- MattB12
- Visitor
12 Jul 2016 19:57 #169941
by MattB12
Yes the original Jimny transfer box and props are still fitted. Thanks, I'll keep a look out for an SJ front prop, I believe they are rare though.
Would a spacer on the diff end of the prop be enough?
- viciouspenguin
- Visitor
12 Jul 2016 20:00 - 12 Jul 2016 20:01 #169942
by viciouspenguin
You could always get one made, that's what I did when I did a 4" lift.
www.baileymorris.co.uk/en/4x4-extreme-land-rover
EDIT | Install - sj410.co.uk/charger/garage/100412.html
Last edit: 12 Jul 2016 20:01 by viciouspenguin.
- MattB12
- Visitor
12 Jul 2016 20:25 #169944
by MattB12
Thank you mate, how much did that cost?
If the prop is too short and on it's limits, would that cause this noise and vibrations i'm getting?
- viciouspenguin
- Visitor
12 Jul 2016 20:28 #169946
by viciouspenguin
I can't remember exactly but it was a few hundred. I would just go for a basic one, the double UJ was a bit overkill
I could cause the vibration, I would poke around underneath to double check things. Check the UJs are ok too.
- OllieNZ
- Visitor
12 Jul 2016 20:40 #169948
by OllieNZ
Replied by OllieNZ on topic Re:Howling/vibrations after 4" suspension lift
It may also be the nose of the rear diff has been dropped to far with the caster correction. It should really be pointing at the output of the transfer case. A spacer would definitely be a good place to start.
- MattB12
- Visitor
12 Jul 2016 20:45 #169949
by MattB12
OK thanks a lot I'll bear that in mind for now.
Would a spacer on the diff end help push it back in?
Just a thought, i have some 31" tyres on the way, because they are going to raise the axle a bit would that help put the prop back within it's limits? Or is that logic a bit skewed.
- MattB12
- Visitor
12 Jul 2016 20:47 - 12 Jul 2016 20:50 #169950
by MattB12
Edit: just seen your response OllieNZ regarding the spacer, thank you.
@ VP - Yes, I also gave the UJ a good eyeballing when the prop was off, I think the prop itself is fine.
Last edit: 12 Jul 2016 20:50 by MattB12.
- viciouspenguin
- Visitor
12 Jul 2016 20:56 #169951
by viciouspenguin
Bigger tyres won't change it, but a prop spacer will. Presumably the radius arms are corrected for the lift and you haven't used standard ones?
Time to create page: 0.104 seconds
