JIMNY: Rear discs brakes and full floating axles
- gus2000
- Visitor
26 Sep 2014 01:02 #125118
by gus2000
Replied by gus2000 on topic JIMNY: Rear discs brakes and full floating axles
Hello, the handbrake is included in the Peugeot brake calliper
The parking cable is some complex..........
In a first test modify the original parking cables extending sheath with a aluminium tube, and removing the original cable spring.
Not work properly, the cable and sheath is short, and the regulation falls short too
Then replace the brake cables using the original of peugeot 206
Jimny Cable
Peugeot Cable
Is necessary to modify the anchorage
now works correctly
Gustavo
Jimny Cable
Peugeot Cable
now works correctly
Gustavo
- Old Blind Dog
- Visitor
21 Oct 2014 23:58 #127146
by Old Blind Dog
Replied by Old Blind Dog on topic JIMNY: Rear discs brakes and full floating axles
Why no the most interesting question. Where did you get halfshafts?
- gus2000
- Visitor
22 Oct 2014 01:56 #127148
by gus2000
hello, I make me a specialist for chip removal machining from a rod of sae 4140 steel, and subsequently quenched and tempered properly
- Thank you received: 260
02 Nov 2014 23:37 #128294
Replied by helijohn on topic JIMNY: Rear discs brakes and full floating axles
First time I have read this thread.....................very very impressed.
- Brave
- Visitor
04 Nov 2014 16:43 - 04 Nov 2014 16:50 #128474
by Brave
Replied by Brave on topic JIMNY: Rear discs brakes and full floating axles
Wow. Top work and top engineering. Fantastic.
Last edit: 04 Nov 2014 16:50 by Brave.
- EmiJimny02
05 Sep 2024 09:28 #257443
by EmiJimny02
Replied by EmiJimny02 on topic JIMNY: Rear discs brakes and full floating axles
ciao mi puoi inviare questi dwg?
Time to create page: 0.095 seconds
