JIMNY: Rear discs brakes and full floating axles
  • gus2000
26 Sep 2014 01:02 #125118 by gus2000
Hello, the handbrake is included in the Peugeot brake calliper
The parking cable is some complex..........
In a first test modify the original parking cables extending sheath with a aluminium tube, and removing the original cable spring.
Not work properly, the cable and sheath is short, and the regulation falls short too
Then replace the brake cables using the original of peugeot 206
Jimny Cable
Peugeot Cable
Is necessary to modify the anchorage
now works correctly
Gustavo
  • Old Blind Dog
21 Oct 2014 23:58 #127146 by Old Blind Dog
Replied by Old Blind Dog on topic JIMNY: Rear discs brakes and full floating axles
Why no the most interesting question. Where did you get halfshafts?
  • gus2000
22 Oct 2014 01:56 #127148 by gus2000
hello, I make me a specialist for chip removal machining from a rod of sae 4140 steel, and subsequently quenched and tempered properly
  • helijohn
02 Nov 2014 23:37 #128294 by helijohn
First time I have read this thread.....................very very impressed. B)
  • Brave
04 Nov 2014 16:43 - 04 Nov 2014 16:50 #128474 by Brave
Wow. Top work and top engineering. Fantastic.
Last edit: 04 Nov 2014 16:50 by Brave.
05 Sep 2024 09:28 #257443 by EmiJimny02
ciao mi puoi inviare questi dwg?
Time to create page: 0.615 seconds
