JIMNY: Rear discs brakes and full floating axles
- gus2000
31 Aug 2014 14:34 #123035
by gus2000
JIMNY: Rear discs brakes and full floating axles was created by gus2000
Hello, Some time ago I am working on install rear discs brakes and full floater axles. Yesterday I did the first test on road.
Navigating www emerges as the recommended use of suzuki front hubs.
Design and manufacture of the adapter plate to the rear axle with support for brake calipers
Reinforcing the end of the rear axle. the original flange with 8mm bolts are insufficient to support the wheel hub
Good fit………….
Finished reinforcing work
Adapters plates with 10mm stud bolts
Brake Caliper (Bosch, rear from Peugeot 206)
Painting
Brake discs…….. (Factory, front Jimny)
1mm disc out as recommended by Bosch
Inside, close but not rubbing
New brake tube hoses
brake tube hoses in position
Half shafts…….in cromo moly steel, heat treated.
Gran Vitara flanges.
Flanges adapted to support the shafts
Axle installed on the Jimny
I hope you like and result useful work
Gustavo
Good fit………….
Painting
Gustavo
- irishguy123
31 Aug 2014 15:01 #123038
by irishguy123
Replied by irishguy123 on topic JIMNY: Rear discs brakes and full floating axles
Very impressive! If you had manual hubs on the rear axel would it allow you to drive in front wheel drive only? Could be useful if you damaged the rear diff etc.
- JuanGuillie
31 Aug 2014 16:33 #123046
by JuanGuillie
Replied by JuanGuillie on topic JIMNY: Rear discs brakes and full floating axles
Nice one, Gustavo.
Great job.
Thumbs up !!!
Great job.
Thumbs up !!!
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
31 Aug 2014 17:12 #123049
by funkyjimny
Replied by funkyjimny on topic JIMNY: Rear discs brakes and full floating axles
Nice work, impressive engineering skills and well thought out.
Gary
Gary
- Cider
31 Aug 2014 20:01 #123065
by Cider
Replied by Cider on topic JIMNY: Rear discs brakes and full floating axles
Very Nice
- Tadpole
01 Sep 2014 07:11 #123087
by Tadpole
Replied by Tadpole on topic JIMNY: Rear discs brakes and full floating axles
Top job as always Gustavo, thanks for sharing ....
Time to create page: 0.459 seconds
