× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Steering Damper Placement
  • Jimnyash
  • Visitor
  • Visitor
24 Sep 2012 15:14 #48672 by Jimnyash
Steering Damper Placement was created by Jimnyash
I'm sure I've seen on here (but for the life of me cant find it now) pictures of steering dampers fitted behind the axle.
I guess this is to stop any damage while off roading.
Is there any other advantage? I don't really want to limit access to the tie down points as I guess at some point, I'll reinforce them somehow with plates etc etc.
  • Jimnyash
  • Visitor
  • Visitor
25 Sep 2012 07:28 #48707 by Jimnyash
Replied by Jimnyash on topic Steering Damper Placement
Hoping to get this ordered to fit at the weekend (as the weather looks a least dry!).
Any thoughts?
  • Smoggy
  • Visitor
  • Visitor
25 Sep 2012 07:57 #48710 by Smoggy
Replied by Smoggy on topic Steering Damper Placement
Dry :S You wanna try being in the north east at the moment. Its been lashing down for 24hours, cant work on car :evil:
25 Sep 2012 10:37 #48712 by maverick
Replied by maverick on topic Steering Damper Placement
Use the SEARCH tab and use STEERING DAMPER - its in there ..
I trid to put in the URL for you in this thread , but got told I had attempted to put in a SPAM message ???
Jalapeño, IISY?
  • Jimnyash
  • Visitor
  • Visitor
25 Sep 2012 10:51 #48714 by Jimnyash
I've tried the Search. At the time there was 159 posts. I just didn't fancy reading each one and hoped someone could help.
25 Sep 2012 10:54 #48715 by maverick
on the basis it wont let me put the URL in here, I've PM'd it to you...
Jalapeño, IISY?
The following user(s) said Thank You: Jimnyash
25 Sep 2012 11:18 #48718 by maverick
Jalapeño, IISY?
25 Sep 2012 11:18 #48719 by maverick
The SEARCH tab is good to use ...
Steering Damper Fitting
Jalapeño, IISY?
  • Jimnyash
  • Visitor
  • Visitor
25 Sep 2012 12:08 #48724 by Jimnyash
Thanks Maverick.
That's not the thread I remember, but it does help.
So it looks like the jimnybits kit. I guess fitting it to the rear steering bar is just more of a pain than fitting it on the front steering bar.
  • Paul4x4
  • Visitor
  • Visitor
25 Sep 2012 13:19 #48726 by Paul4x4
Replied by Paul4x4 on topic Steering Damper Placement
I wouldn't be too worried about the damper getting damaged, because it sits in there pretty high up, so it takes a blind or very crappy driver to smash the front end against a rock or something high enough to hit the damper... :whistle:
  • Keefe
  • Visitor
  • Visitor
25 Sep 2012 14:20 #48727 by Keefe
Replied by Keefe on topic Steering Damper Placement
I've got the kit that fits behind the axle. Clamps on the rear tie bar and onto the clamp round the axle.
Only thing is, it's not fitted so no piccies I'm afraid.
I attached it to the front of the axle to start with and the angle that the damper sits at is quite steep but after a phone call, it was decided that the bracket went to the rear of the axle and the damper behind. Not as steep an angle and as a plus, out of harms way.
Will be fitting it to the rear once the Jim starts going back together.
K :-)
  • goatboy
  • Visitor
  • Visitor
25 Sep 2012 15:25 - 25 Sep 2012 15:28 #48731 by goatboy
Replied by goatboy on topic Steering Damper Placement
Mines on the front tie bar but its well out of the way.
I just have the basic kit off here but I wasn't 100% comfortable with the angle and position when the other end of the damper was just attached to the tie down points so I made up a little section of steel that bolts onto the tie down point and then the damper bolts onto that. Not dissimilar to the Rhino ray set-up but a bit cheaper!
You can just about see it in this picture.
It makes it a little further back and the angle of the damper a bit flatter.
Its well out of the way, not sure how you would manage to damage it as there is a lot of other stuff in the way first.
Last edit: 25 Sep 2012 15:28 by goatboy.
Time to create page: 0.135 seconds
Powered by Kunena Forum
