BigJimnyMeet 2024
broken rear shock bolt - done
- Thank you received: 75
01 May 2012 18:50 - 06 May 2012 13:37 #39090
by robs5230
standard jimny - for now
broken rear shock bolt - done was created by robs5230
the chap i am buying my jimny from has just phoned to say it has a broken rear shock bolt that he found on checking it over before i collect. it is a lower bolt.
how big an issue is this and whats the way to go about sorting it. the car isnt far away and i can get it home without issues , just need to know how to sort it.
any help appreciated thanks , rob
Last edit: 06 May 2012 13:37 by robs5230. Reason: completed
- Thank you received: 153
01 May 2012 18:57 #39091
by supergaz
Replied by supergaz on topic Re: broken rear shock bolt - help please
Best thing to do is to grind the bolt flush, centre punch the centre, drill all the way through with a good quality drill bit, (NOT THE B&Q RUBBISH) Then use a long bolt all the way through with a nyloc nut. Do this both sides as if it is to shear in the future its a simple knock it out job to replace.
01 May 2012 18:59 - 01 May 2012 19:00 #39092
Replied by mlines on topic Re: broken rear shock bolt - help please
www.bigjimny.com/index.php/bigjimny-blog...1-first-fault-v15-51
www.bigjimny.com/index.php/bigjimny-blog...-gone-updated-v15-91
Enjoy!
Enjoy!
Last edit: 01 May 2012 19:00 by mlines.
The following user(s) said Thank You: robs5230
01 May 2012 19:12 #39094
by robs5230
Replied by robs5230 on topic Re: broken rear shock bolt - help please
nice cheers guys. will the brackets in the jimny shop help when refitting ??
01 May 2012 19:20 #39095
by supergaz
The brackets will take the stress out of the lower bush if you have a lift, they also add an extra 1.5" length to the shock.
- reaper
- Visitor
01 May 2012 19:28 #39097
by reaper
Replied by reaper on topic Re: broken rear shock bolt - help please
they can be hard to drill , if you can weld weld a nut or bar onto what is left and just unscrew it .
i would recommend then drilling out and bolting right through
01 May 2012 19:39 #39098
by robs5230
cheers reaper , may be the way to go .
01 May 2012 19:41 #39099
by robs5230
aint even got it home yet an its bust
- Thank you received: 210
01 May 2012 19:55 - 01 May 2012 19:56 #39100
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: broken rear shock bolt - help please
The rear shock brackets are only needed if you have got a 2" lift fitted or spring spacers.
2002 JLX Soft Top
Last edit: 01 May 2012 19:56 by dirtydogz.
01 May 2012 20:02 #39102
by robs5230
how dumb do i look ? bought this unseen but its had lots done just not sure what exactly. all will be revealed tomorrow night
03 May 2012 18:38 #39233
by mcjimny
Replied by mcjimny on topic Re: broken rear shock bolt - help please
The drill bit you need is a HSS bit, not sure on size though. Take it steady though don't have the drill too fast.
- reaper
- Visitor
03 May 2012 18:44 #39235
by reaper
If you want to use the bolt through method its a 12mm drill bit , take it nice and slow with plenty of cutting oil or it will just burn up or chip the cutting face
